Strut problems
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=7185
Printed Date: May-09-2024 at 7:42pm
Topic: Strut problems
Posted By: redneck7
Subject: Strut problems
Date Posted: June-21-2007 at 4:43pm
Since owning my boat the cutlass bearing has worked it's way partially out of the strut a few times (and I just put it back in)...took the boat in for the 20hour service on the new engine and while it was there I figured I'd get em to replace that cutlass bearing, realign the engine/shaft, etc...make a full job of it.
Fella called yesterday and said that the reason the cutlass bearing had worked it's way out a few times was because the previous owner had run it w/out one at some point and the inside of the strut is wallowed out.
Short of it is that I need some strut work, or a new strut altogether...we can't find a strut in a few phone calls, so now we're either going to bore/hone till it matches a larger cutlass bearing or try to fill, then bore and hone back to normal size.
Anyone know of a location of a strut for a 1983 Fish Nautique (new or used) or have any thoughts on either version of machining the one I have?
Thanks
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=1620&sort=&pagenum=1&yrstart=1981&yrend=1985 - My 1983 Fish Nautique
Posted By: nuttyskier2002
Date Posted: June-21-2007 at 5:34pm
Don't know how bad your strut is wallowed out but I've seen struts use set screws to hold the cutless bearing in place. If yours is stainless (I think most are now days) it might be tough drilling and tapping but I believe this is a option. I don't think you have much to lose by trying.
------------- 95 Malibu Echelon w/Mercruiser 350 Magnum Skier
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Date Posted: June-21-2007 at 6:52pm
7, A new strut shouldn't be that hard to find. No matter who made the boat they have always been made in standard sizes and angles. Take a look:
http://www.classicboating.com/Underwater_gear.html - struts
The next larger cutlass is 1/8" larger OD so you won't have much to machine especially if it has been wallowed out. The brass will be easy to cut but the set up with the angle on a mill will take some time. Good luck
Edit: Have you considered using a Loctite bearing retainer compound? Don't know how worn your strut is but the Loctite will fill up to .015 on each side. If you ever have to change the cutlass it may make it a little harder to remove but you have to cut old ones out anyway.
