buying new carb question
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=7533
Printed Date: May-15-2024 at 11:39pm
Topic: buying new carb question
Posted By: weitekampt
Subject: buying new carb question
Date Posted: July-15-2007 at 11:14pm
I was told to shop summit to buy a new marine carb. It is cheaper than other outfits, but I have many selections at other companies like jegs. I look at all 600 cfm carbs and read the details which are the same i.e. single feed inlet, vacuum secondaries, electric choke, etc but the prices are very different. From my observations, the fuel inlet placement on the primary bowl is the only real difference. My carb is obviously the most expensive as luck would have it. Wondering if the cheaper carbs would work if I fabbed up a new hard line from pump to carb. I am probably way off base here, but just thougt I would throw out the question.
------------- 1993 SkiNautique ProTec
2009 Boatmate trailer.
1240 hours on meter.
http://www.correctcraftfan.com/diaries/details.asp?ID=1559&sort=&pagenum=2&yrstart=1991&yrend=1995 - 1993 Ski Nautique
Posted By: Rinautique76
Date Posted: July-15-2007 at 11:26pm
yes it will work as long as the carb is marine
------------- ron benoit
Posted By: Tim D
Date Posted: July-16-2007 at 12:19am
Why can't you fix the original?
------------- Tim D
Date Posted: July-16-2007 at 12:24am
Well, the base plate was warped when I got it back. It wobbled on the intake spacer. I didn't have many options but stick it on there.
Talking to boatdr he said when your carb is warped, it is toast and will never be right.
So here I am pricing new carbs and seeing what is the most affordable but offer excellent performance.
So basically I can get any (within reason) 600cfm carb even if it has a different fuel inlet but change the piping to make it work?
Posted By: Tim D
Date Posted: July-16-2007 at 12:57am
Carolina Carburetor Specialists may have a used one.
------------- Tim D
Posted By: JasonR
Date Posted: July-16-2007 at 3:43pm
I replaced my Holley 600cfm marine (original) with the same from Jeg's. They were the cheapest new carb. I had to find a adapter to go from the fuel inlet to a basic flare fitting. I replaced the tubing also from the pump to the carb. I have had it on for about three years and have had no problems. I was happy with Jeg's and they were noticably cheaper than other suppliers
------------- '86 2001 800hrs
Date Posted: July-16-2007 at 5:22pm
i went with a edlebroch 4 years ago and never had a regret i prefer it over the holley any day of the week
Posted By: bmiller
Date Posted: July-16-2007 at 5:44pm
Well I can only say go back with the same carb that the engine was designed for.I tried the edelbrock on mine and had issues.A 600cfm carb was to much for a stock 302.Thats the reason the 302's need 450 cfm carbs from holley.Also there were some float issues with the edelbrock carb.When I had those issue's I called tech support for edelbrock an they said that due to the angle of the engines in the engine compartment,the carb would not run right.I tried everything from leveling plates to everything under the sun.My point is just go back to the original carb that the boat came with.
Posted By: Tim D
Date Posted: July-17-2007 at 12:31am
I agree, I put a higher cfm holley on mine, it didn't perform better, just used more gas. So I went back to the same size.
------------- Tim D
