1992 PCM Fuel Filter |
1993R ![]() Groupie ![]() Joined: July-27-2005 Location: Hawthorne, FL. Status: Offline Points: 52 |
![]() ![]() ![]() ![]() ![]() Posted: July-27-2005 at 6:43pm |
I have a 92 with the standard PCM powerplant. I have recently had problems with the fuel delivery and was wanting to clean/replace the fuel filter. I have drained the water/fuel seperator but cannot locate the fuel filter. I know that Holley carbs have a screen on the inside where the fuel line attaches. Anybody know where the fuel filter is? Thanks....
marks ![]() Groupie ![]() Joined: April-23-2004 Location: United States Status: Offline Points: 96 |
Is your water seperator a big orange can mounted just to the side of the engine on the stringer? If so, it is also your fuel filter. The body of the can unscrews like an oil filter. There is a replaceable filter element inside. You can order a replacement from SKIDIM. It is a Fram long filter. Sometimes the can is really difficult to unscrew. I find it easier to remove the fuel lines and unbolt the whole thing from the mounting bracket. Then I can get at it with some big wrenches.
Thanks,
That's what I'll do. I tried getting it off with a strap wrench but it did not budge. |
munday ![]() Guest ![]() |
Go to FRAM web site,dealer near you.
Bought new filter for my 92sn for less than 10 dollars. ccs1136 is what your looking for. |
