  New Posts New Posts RSS Feed - 2002 Air Nautique
2002 Air Nautique
garymckee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garymckee Quote  Post ReplyReply Direct Link To This Post Topic: 2002 Air Nautique
    Posted: September-11-2018 at 12:52pm
My boat is holding water and not kicking in the auto bilge when the ski locker has about 5 inches in it but the pump kicks on and off without pumping out water. Any suggestions why?
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2018 at 1:07pm
Bad pump? Hole in the outlet hose?
That's about it.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2018 at 2:21pm
Mud dobbers 2” inside the outlet? Happens to me yearly and same with furnace exhaust on my camper.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2018 at 11:27am
Tripped fuse? Check the breaker box on the boat under the helm. Mostly likely bad pump.
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2018 at 3:51pm
According to the owners manuals there are two pumps. Are both running when you hear it? Maybe only the pump that is not in water is running? How long does the pump stay on??
From the manual.
"The bilge pump switch turns on the bilge pumps. There is a bilge pump down by the pylon and another bilge pump back by the rudder. When you push the bilge pump key on the keypad, both pumps will come on and run for several moments to “sense” of there is water in the bilge."
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
