  New Posts New Posts RSS Feed - Plexiglass windshield restoration
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Topic: Plexiglass windshield restoration
    Posted: December-23-2024 at 3:55pm
Thought I would make a separate post regarding the windshield for the Collegian since this might be useful in general for any boat with an acrylic windshield.
The windshield that came with the Collegian was an absolute mess and I wasn’t really sure if it could be saved.  After watching a few YouTube videos I decided to try to restore it.    I was already resolved to having to find a replacement so there wasn’t anything to lose.
Tools used were a 6” random orbit sander. With 2000 and 3000 grit paper
An 8” grinder with a heavy wool pad
An auto detailing Rupes polisher with wool pad and three grades of finishing compound.  You could easily get away with a Harbor Freight polisher, the Rupes is overkill but I ‘ve had it for years and use it on all my vehicles and boats .
Initially I wet sanded by hand but I couldn’t get all the deep scratches out so I turned to the orbital with 2000 then 3000 dry sanding.
Next was a pass the heavy wool pad using Dr Beasley 150 compound.
Following that with a wool pad and the same compound on the polisher.
Then ran through the 3 finishing compounds on the polisher.
I also buffed the aluminum trim with some Tripoli on a harbor freight buffing wheel.
Came out pretty decent and was certainly worth the effort because finding these old windshields in good condition is tough to do.  There are still a few deep scratches that I just couldn’t get out but I’m satisfied with it.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2024 at 6:08pm
Impressive !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2024 at 5:50am
"Came out pretty decent and was certainly worth the effort because finding these old windshields in good condition is tough to do.  There are still a few deep scratches that I just couldn’t get out but I’m satisfied with it as you can see my very attractive helper/wife in the reflection holding up the finished project for photographic evidence that it works!"
There.......I fixed it for you Magicman. ! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2024 at 8:34am
I continue to be impressed with the work you do!  That is quite the transformation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2024 at 10:28am
Remarkable!!
Now have hope for saving Dunphy plexi...
Question: are you replacing the rubber channel (plexi to frame) and if so, where did u find?
Again, great work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2024 at 10:54am
Originally posted by MourningWood MourningWood wrote:
Remarkable!!
Again, great work!
There is no rubber gasket on this one,  there are metal clips inside the metal frame that hold the plexi in place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2024 at 10:59am
Love it.  Thanks Timbob
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: December-26-2024 at 8:17am
Magnificent indeed
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2024 at 9:23am
Did you sand the inside?
Now don’t crack it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-27-2024 at 10:25am
Now don’t crack it!
Yes both sides were a mess.  The inside is a little more difficult to do.
I was worried about too much pressure and cracking it but it went well.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2025 at 10:00pm
Looks really really good. But, all you do seems to turn out that way.
A long long time ago I did the '66 Mustang w/s with 3M Glazing Compound (pink) no sanding, just two buffings, looked new.
Anyway, do you have the little rubber grommets ?   I just found some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2025 at 8:10pm
You don’t happen to have any of the hold down brackets do you?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2025 at 8:25pm
   Sorry Alan, Don't have the little chrome or stainless eye-bolt thingies.    Not real sure, but maybe one of the big box stores may accidently have a similar type of hardware.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2025 at 9:32pm
Thanks, time to get creative.   Alan
