Slalom Ski |
Page <12 |
p/allen ![]() Gold Member ![]() ![]() Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
Try to go outside the wake on 2 skis towards the side you are going to drop . This will help you with your balance because it wont allow the ski to wobble back and forth when you do finally drop { probably about 15 to 20 feet out side the wake }. Then drag your foot, on the top of your foot and slitely behind your other foot that is in the ski . This is the way I learned to go on one ski . Give it a try . I hope it works for you .
The Lake ![]() Platinum Member ![]() ![]() Joined: May-13-2005 Location: Lk Winnebago MO Status: Offline Points: 1157 |
Hey John,
Maybe I missed it, but you obviously have your boat back together. Did your project work out OK? Good luck on the skiing. If you keep the ski between you and the boat you're up! Chuck |
behindpropeller ![]() Platinum Member ![]() Joined: July-31-2006 Status: Offline Points: 1810 |
Ski Team is always looking for old skis for drop skis. Bring your kids over some time and I will take you guys out. Tim |
Barracuda ![]() Moderator Group ![]() ![]() Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
Haven't seen one of those in ages. I think my dad still has one. When you get tired, you can lock the handles together behind your back and take a rest, right ![]() |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
eric, check your email
I got a pair of Red Obrian combos in my garage if anybody wants them, make a donation and I'll send them to you
eric |
For what you're doing, those skis will work fine. Do like Quinner says and just lift the ski a few inches off the water. Try both ski's. One will feel more comfortable than the other one. The ski(foot) that is on the water when you feel most comfortable will be the forward foot when you try to drop one. Once that is determined, you can try to drop the other one. Take the boat boat speed up a couple more MPH. When you drop the ski, don't be in a hurry to put your rear foot back on the ski. Just leave it drag around the whole lake if you need to. You'll find that as soon as you try to put your rear foot behind the front foot, you'll probably go down. That's where most people have the most issues. Finding your balance on that single ski is the trick. After you ride around for a while just dragging that rear foot, you'll become more balanced and comfortable on the ski. SLOWLY move your trailing foot behind your front foot and just set it on the ski. Don't try to put it in the stirup yet. Get used to the feeling of having both feet in line. That will take a little getting used to also. As you get more comfortable, you can ease that rear foot into the stirup. Once you get comfortable on the ski and dropping one, then feel free to start learning deepwater starts. If you have a boom, that is a great aid for learning the drop, getting your balance and finally the deepwater start. Good luck and let us know how you're doing. |
Eddie |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7966 |
You got to be competent on 2 skis first, then drop one until you can get your foot in the rear boot, and once you have balance on one ski and can cross the wake and generally ski on one, start working on your deep water start.
bkhallpass ![]() Grand Poobah ![]() ![]() Joined: March-29-2005 Location: United States Status: Offline Points: 4723 |
My mom. Up on first try ever, and not very athlethic at that. The trick is she did what she was instructed to do. Knees bent, arms straight, let the boat pull you on top of the water. Never changes. BKH |
Livin' the Dream
You will need a lot of luck to be successful with these tips ^^^ |
Herdski ![]() Newbie ![]() Joined: July-09-2007 Location: United States Status: Offline Points: 12 |
We have always had luck teaching slalom skiers with a two handled rope. If you stick you ski right between the two handles it keeps your ski steady. Lean back and let the boat do the work. If you get two much weight on your front foot the ski wants to go all over the place. Good luck!!
62 wood ![]() Grand Poobah ![]() ![]() Joined: February-19-2005 Location: NW IL Status: Offline Points: 4527 |
no problem on the ski... the only reason I asked is you also have the option of dragging the "back" leg in the water.. can help with balance. |
If you find yourself going out the front on the start you are standing up to quick.
If you find the ski wobbly when you are up and a lot of spray out the front, put some more weight on your front foot. Tim |
jon4pres ![]() Senior Member ![]() ![]() Joined: September-19-2005 Location: United States Status: Offline Points: 275 |
quinner, I will try to drop one next time I go out but I think part of my problem is that I am having the driver take off to fast.
62, Just a strap. I know it is sad but I have owned a boat that says SKI on the side of it for a couple of years and not ever even had a ski in it. We went on vacation with the whole family a couple of weeks ago and my mother bought a pair of cheap skis at walmart. I am sure they are far from the best. |
Your ski have a boot or a stap for the rear binding?
Jon,
Keep skiing on 2, while riding lift the ski that would not be your forward foot slalom (same foot as boarding), from there if you can then drop the ski and work on skiing slalom. IMHO it is easier to teach someone to ski on 1 then work on your starts. Some of the basics on slalom start are keep your arms extended in front of you, rope should be on the same side of your ski as your rear leg/foot, do not pull in on the rope, forward foot knee in your chest, slowly rise out of tuck through the pull with your shoulders over your foot, butt out and knee forwards just a bit. Rear foot in or out is debatable, try both, if out once up don't be in a hurry to get foot in the rear toe right away, set it on the ski and when stable slip foot in toe plate. Be sure your driver does not over throttle, slow easy throttle is fine, if the rope is coming out of your hands or you are going over the top start a bit slower. You can do it!! |
Ya gotta walk before you run. Drop one first so you get the idea what it feels like to balance on one ski. I've never seen anybody do a slalom deepwater start before learning how to slalom first. If you want to continue to drink half the lake just keep doing what you're doing.
Eddie |
No, I skied on 2 when I was 10 years old and then moved on to kneeboard and now wakeboard.
I did get up on 2 a couple of weeks ago just to make sure that I could even do that. I was going to drop one but there was other boat trafic around. It is going to be tough to find a good place on the lake where I go to drop a ski. I would really like to just learn how to get up on 1. |
Jon, Have you tried dropping one ski yet?
I want to learn how to slalom and I need some tips. I tried to get up for the first time on a slalom a coupld of weeks ago and all I managed to do was drink a lot of the lake.
I will take any good pointers. Thanks Jon |
Page <12 |
