98 Chevy k1500 Trans surging, hard brake |
69 Mustang ![]() Senior Member ![]() Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
![]() ![]() ![]() ![]() ![]() Posted: May-11-2007 at 12:22am |
Hi Guys,
I have a 98 Chevy k1500 - 3 in. lift, 33's with 148,000 on it. Today I had something I've never experienced before. At just above idle (1000 rpm) when I step on the brake the pedal is hard and the truck will lurch forward - not good. When the truck finally stops and I hold my foot on the pedal there is a hissing noise inside the cab and the rpms hold around 1000??? If I shift into neutral and take my foot off the brake pedal the rpms come down and the whole system works properly. I miss my 78 CJ7...knew how to fix that. |
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Online Points: 3372 |
Vacuum leak in the brake booster vac assist, I suspect.
River Rat to Mole |
eric lavine ![]() Grand Poobah ![]() Joined: August-13-2006 Location: United States Status: Offline Points: 13413 |
for sure gotta ski, either the hose going to the booster or the diaphram on the booster itself, the hiss you are hearing is vacuum leaking, look for oil near the booster,
Thanks guys, I appreciate the help. I will try and trace the problem to see if I can fix it before I go in for service.
This is only one reason why I love this forum, thanks again. |
