Hi guys
After repairing the oil pan of our Barefoot Excel nautique 351w I got the engine back in and running. When I faked a lake, the oil pressure was at 10psi, which i already think was weird, because last year it was around 50-60. but maybe when it was already hot, so I didn't think of much.
When we went to the harbor and put the boat in. The gauge showed no pressure at all. but no knocking sounds or anything as well. We carefully cruised at 3k-3.5k rpm and everything was fine. Since all the connections had been loose, I figured a loose cable or ground. I have personally filled and checked the oil level.
And normally we also have a red light that comes up in idle and goes away when the engine goes above 1200 rpm or so? It litterally states ''if light is still on beyond 1200 rpm, shut down engine''. Or something similar in other words. But this light also does not work. I did had to repair and solder a wire to the oil pressure switch on the v-drive. It's not a very good one if I have to be honest. Is this the red dashboard light issue?
When I went back yesterday, the gauge was working again and showing 10psi. When i revved it a little, it would not increase or decrease.
I disconnected the cable that comes from the sender and then the gauge drops to 0, obviously. I checked the connection at the sender, and it looks fine. I did notice a oil pressure switch on a T at the oil pressure sender, but we do not use this anymore. The engine was a protec engine once and it is now carbureted.
My question 1. Can I try to take out the sender without to much of a oil spil... 2. how can i further diagnose the gauge? 3. Does this red warning light have anything to do with this or is this a problem on its own?
Thanks in advance Gino Belgium
