  New Posts New Posts RSS Feed - Thermostats
Thermostats
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Topic: Thermostats
    Posted: January-06-2005 at 9:03pm
Is there anything special about a thermostat used in a marine application? (Bronse, brass, gold, stainless, etc.?) What temperature rating is best? 160 Deg? Insight will be appreciated.
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: January-06-2005 at 9:21pm
nothing special unless you run in salt water.
when u buy 1 for your truck,boat or anything else with an engine.check it on the stove with a pan of boiling water & a thermometer.if it's rated to open at 160.give it about 10 degrees either way to activate.
6 out of 10 ain't worth the metal they were made of.
kenny g
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2005 at 12:33am
EXCELLENT advice! 6 out of 10 might be conservative.
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2005 at 1:24am
I do run in salt water. So, what kind of thermostat is best?
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2005 at 11:44am
Jim,
For running in salt water you should use a 140 or 143 degree thermostat to limit the corrosion. There are some web sites or threads that expand on the reasoning behind it. As for the material, just pick up a marine piece and you should be fine.
ReidP
1973 Mustang
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2005 at 4:34pm
Go to your local NAPA and get a marine 142 degree thermostat. That is what I have in my "66 Mustang. That was the degree on the original and speaking of the original, it was made with a hinge on one side and opened like a door unlike ones today which open from the center.
Tim D
