  New Posts New Posts RSS Feed - First time out and had to be towed in...
Chris R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris R Quote  Post ReplyReply Direct Link To This Post Topic: First time out and had to be towed in...
    Posted: October-14-2008 at 10:01pm
We picked up our 2000 Super Sport about 6-7 weeks ago but between the weather and work we hadn't been able to actually get the boat onto the water until this weekend. Tried one weekend before only to drive an hour and have it just click because of the battery
Anyways, for the first 90 minutes we were just cruising around and getting used to the boat. Nothing out of the ordinary, and everything was working fine. I decided to do a set with my wife driving and everything seemed fine while I was going for 20-30 minutes. Got out and she gets ready to do her set. I start it up and as I accelerate it she falls, but as I'm heading back to circle I notice a bit of a hiccup/hesitation. As I push the handle a bit more it just stalls. Start it back up, seems fine. Get back to my wife and get ready to start her pull and as soon as I accelerate it hiccups and stalls. Now I'm getting a bit nervous, so I tell her we'll just call it a day and head back. Get all back in and it gets up going fine and at around 15 mph it starts the hiccup again and then stalls. Start it up and as soon as I try to start going it stalls. I putz around checking the fluids again (I checked before we left), cleaning the water filter (some seaweed) and generally trying to figure out what could be wrong. We finally just flag someone down and they tow us back, we load up and head home. I haven't had any time to really start looking into it, but I'm a bit stumped.
It idles fine, without any issue, and had a full tank of gas which I put in a few weeks ago. The one thing that really worries me honestly is the fact that I cannot spin the prop by hand out of the water. This is my first Nautique and inboard, my family's always had I/Os, but I'd assume the prop should spin somewhat freely I'm going to give the guys we bought it from a call, but just haven't had the time yet. Any ideas or suggestions on where to start?
Brktracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brktracer Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2008 at 10:57pm
Sounds like it needs an alignment. That's probably why the prop won't turn. If you're mechanically inclined you can do it yourself. Do a search for "alignment"
As far as the engine goes, it sounds like you might have some water in the gas or the fuel filter is stopped up.
Anyway, welcome to the site! Lots of help here!
Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2008 at 8:18am
Chris,
Welcome! Hope we can help you out.
Your boat is a V drive and they can be a real PITA to align plus I know there are sometimes issues with the V drive gearbox itself. How inclined are you to do this yourself? Take a look at the alignment thread alignment by Eric and get back to us. This thread is for a straight drive but it will give you the basic idea.
Regarding the engine, get a new fuel filter/water separator cartridge on it and see what happens.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2008 at 9:35am
I know next to nothing about V-drives, but it almost sounds like the engine shifted during his run causing it to bind.
1988 BFN-sold
azeus17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote azeus17 Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2008 at 8:54pm
To me it sounds like two separate and unrelated issues. I would bet that it was out of alignment before you went out and you only noticed because you were checking around because of the engine issue.
I know nothing about v-drives, but the engines are the same. I think the other guys have given a good place to start.
My biggest question is:
How the heck to you buy a new boat and not use it for 6-7 weeks?!!!!
You have more patience than me, my friend.
Regardless, you have come to the right place.
Welcome.
Boats:
Current: 02 SANTE
Sold: 89 Sport Nautique
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2008 at 10:54am
sometimes the trans will have a drag from warped plates in the forward pack and it will be hard to turn the prop, not enough is known at this point, it also sounds like its starving for fuel because of the hiccup out of the carb im assuming. might be water might be the filter or even the anti siphon valve
