Shifter Knob |
skyhawkflyer
Senior Member Joined: February-08-2005 Location: Zimbabwe Status: Offline Points: 275 |
Posted: February-16-2005 at 11:24am |
I'm going to replace the shifter knob on my 87 SN. What is the best way to get this off without damaging the shifter??? I thought it just screwed off, but if it does mine must be really stuck on there good. I couldn't budge it. Any idea's??? TJ
79nautique
I was under the impression they where held on by a set screw?
Tim D
Maybe a set screw with a small allens wrench head.
Tim D
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
Mine has a brass threaded insert in the white knob, of course mine is a 39 year old Morse control. I always thought it would be cool to find an eight ball from one of those minature pool table sets, and use that!
Morfoot
An 8-ball shifter knob would be kinda hot in the summer baking all day don't you think????
skyhawkflyer
I'm going to try and take it off on saturday when i pull some other maintenance in the garage. I just don't want to damage my morse shifter in the process. If anybody has any idea's let me know. TJ
Tribal150
Senior Member Joined: December-24-2003 Location: United States Status: Offline Points: 137 |
If you are interested in a custom shift knob check out.
www.flameball.com If you can measure the thread they can custom make it for you, I have one on my 76 nautique. Rob |
plattebum2001
Newbie Joined: December-18-2004 Location: United States Status: Offline Points: 12 |
My 85 2001 screwed off.
The knob was pretty weathered and I bought a new replacement from Morse. The replacement had no character. I grabbed a 3/8 bolt about 3" long , cut off the head, put the shank in my 3/8 drill, and screwed the threaded end in my original knob. Crank up the power with some sandpaper , steel wool and some Tru-Oil for gunstocks. WOW !! 3-4 Coats spinning the Tru-Oil on with your finger at a slow speed. Good as new. |
skyhawkflyer
Guest |
I'm going to see if I can get mine off tomorrow Plattebum and give that a try. I thought that the wood was stained and polyurethaned? Would that work? I just want to restore the finish if I can get it off without destroying the shifter, it's weathered bad. TJ
jameski
Senior Member Joined: May-18-2004 Location: United States Status: Offline Points: 368 |
I did mine last winter. Mine was also weathered baddly. I put it in my drill press at a very high speed and sanded it down with very coarse sandpaper (46 grit). After I finally got the weathered wood off, I sanded it smooth with finer sandpaper. Then I sprayed it with about 10 coats of Helmsman Spar Urethane by Minwax (from Wal-Mart). I didn't use any stain, but the wood grain really looks great with the clear urethane. I expect it will continue to shine like a glass ball for years.
jcawley3
Groupie Joined: January-31-2004 Location: United States Status: Offline Points: 82 |
my 86 just screws off it was really hard the first time
97 sport
Guest |
I refinshed mine last winter. It just unscrews off. Right hand thread. Maybe you can support the shifter with a pair of non marring pliers then use a strap wrench on the knob?
66polyhead
I think you should cut it off with a hack saw, and get a white one. A dark brown, wooden one would be kinda hot baking all day in the summer don't ya think?
skyhawkflyer
I tried getting it off yesterday, it just won't budge. I'm going back down to the lake this comming weekend and I'll give it another try with a strap wrench. I bought a cheap one from Harbour Freight. It doesn't have a set screw, I did check that out. I can't believe it's on there that tight, unless the prior owner put some glue on the threads or something like that.... TJ
I like the drill press idea, I have access to one of those! |
66polyhead
TJ, go to www.kanolabs.com, they make a wonderful product called Kroil. It is a creeping oil that gets into a 1 millionth inch space. I've used it for years, it works great, but smells to high heavens!
66polyhead
Be careful torquing on the knob, It has a threaded insert that is knurled on the outside, and pressed into the wood, then screwed onto the control lever. Too much force, and you'll just remove the knob from the insert!!! Patience Grasshopper...
skyhawkflyer
66poly, Thanks! I work in a flight department and we have lots of Kroil. I'll give it some this weekend and maybe a few light taps ith a rubber mallet too. It stinks, but works well!
And the shifter knob dilemma goes on..... TJ |
skyhawkflyer
66Poly. Got the knob off, destroyed it with the strap wrench. Time for a new one. thanks
hotwife
Guest |
Sorry you destroyed your knob! This has been a very entertaining post to follow
66polyhead
Sorry about the knob. Don't forget to put alittle anti-seize on the threads before screwing the new one on!
workky
Senior Member Joined: June-26-2004 Location: Marietta,Ga Status: Offline Points: 206 |
mine just screwed off,i have an 8 ball shifter.which i dont care for to much.it was there when i bought it(84 nautique)
captan1
Senior Member Joined: June-02-2004 Location: United States Status: Offline Points: 180 |
20 posts for getting a ball off? Someone must have used super glue.
I've got a white 4speed sifter knob, fits my hand nice. |
skyhawkflyer
It appeared to be super glued on. I destroyed the wooden portion trying to remove the ball with a strap wrench, and then I lost patience. I removed the remaining threaded insert with a large pair of vice grips. All that's left is to order up a new knob from Discount Inboard Marine!
