  New Posts New Posts RSS Feed - Exhaust Manifold Drain
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust Manifold Drain
    Posted: April-13-2009 at 10:52am
Does anyone know what size pipe thread the drain port is on the exhaust manifold? My guess is 3/4-14 NPT.
I want to buy a tap as the threads on mine are pretty corroded.
Thanks
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2009 at 4:45pm
Chris,
If you have the riser type PCM's then yes, it's a 3/4" pipe.
You may want to consider putting stop cocks back in after you chase the holes. I have these on all my boats.
They are a "high end" radiator drain but unlike the typical cheap ones, the whole center valve stem is removable so you can still probe the hole with some wire to make sure there isn't any sediment plugging it. Merc uses them on their engines. The largest pipe size is 3/8" so you'll need a 3/8 by 3/4 brass bush.
stop cock at Mcmaster
Mcmaster would be a good source for the tap and bush too.
If you go with the drains, might as well do the other ones too. The block should be 1/4" pipe and the water pump "U" tube should be 1/8".
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2009 at 8:06pm
Thanks Pete, going to order a tap ($10) off of ebay tonight.
They are expensive ($40) to buy retail!
My boat is still in storage (going to fetch it this weekend) so i can't measure it until then.
I'll look at petcocks, good idea!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2009 at 9:35pm
That's why I suggested looking at Mcmaster for the tap too. Nice thing about them is you buy industrial priced stuff. I go back with them into the early 70's at work. It's rare that they won't have something. I did stump them the other day looking for a left hand 1/4" pipe plug. The high pressure side of some pressure regulators (for the CO2) are left hand thread and I was thinking of removing the gauge.
$23.00 3/4" pipe tap at Mcmaster
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2009 at 2:27am
The u/j tube is also 1/4" (on our 88, so i'll assume 89 also)
