  New Posts New Posts RSS Feed - Installing New Rub Rail
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Installing New Rub Rail
    Posted: May-15-2009 at 3:07pm
I just received a new rub rail I ordered from Whitelake. I had two options when ordering the rub rail.
1. Rub rail kit with rubrail, black insert, screws, and end caps. $496
2. Rub rail only $219
I ordered the rub rail only and plan on trying to reuse the insert and end caps and buy new screws. I have read other posts where people have done this by flipping the insert and using the unexposed side on the new rub rail.
The problem I think I may have is that the the rub rail is pretty smashed up at the bow and the insert appears to be almost flat at the nose of the bow. Will this be a problem? I'm hoping with a little heat I can make this work. What do you think? any suggestions or tips?
I plan on removing all the screws then filling the holes with epoxy, 5200, or caulk (which would be best?) than drilling new holes and and using new screws.
Any tips or suggestions are, as always, very much appreciated.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2009 at 3:46pm
I don't think I've ever read about anyone flipping the plastic insert. I have read of folks flippin the rope insert. I thought that the plastic inserts (which you can order in different colors were convex and only went in one way. Obviously, ICBW.
I have seen two types of installations: 1) fill the holes with epoxy and redrill. Two, chalk line or grease pencil line at every hole, and reuse the existing holes.
Personally I'd buy new screws. My time in having to do it again is two valuable. I would buy new screws and know that I won't have to do it again as long as I own this boat.
BKH
Livin' the Dream
