Jump Start Battery - Opinions? |
Jason
Guest |
Posted: April-26-2005 at 5:07pm |
http://hitches4less.com/jumpstarters.html
For peace of mind with my new stereo install, I was thinking about purchasing one of the jump starter battery boxes in case I run my battery down at the lake. What size do I need? Will be these effective with a deep cycle battery? I thought about adding another battery, but this jump starter would come in handy with starting stuff around the garage or just nice to have in my truck to help myself of someone else out. Any opinions??? thanks |
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
The battery jumper pack is ok for jumping the battery but to used as a second battery no way.
Instead install a second battery with an isolator & hook your stereo & accessories to it. This will allow the alternator to charge both batteries when under way but to discharge only the one battery when using the stereo system leaving a well charged batter for starting only. This is a great system to use. These isolators can cost $75.00- $150.00 but peace of mind from a reserve fully charged battery is hard to beat. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
Deep cycle batteries are not designed for spinning American V8 engines. too much internal resistance. They result in burned cables, crusty starters, and solenoids with welded contacts.
If you have starting problems consider ditching the deep cycle battery Get a nice 825 Amp cranking battery and fugetaboutit. |
River Rat to Mole |
Texas88
Newbie Joined: April-23-2005 Location: United States Status: Offline Points: 19 |
Hey guys, how does an isolator work, how would you install one and tell me again what is wrong with starting a V8 with a deep cycle.
Thanks, Bryan |
GottaSki
The Deep Cycle battery cannot provide BOTH high amps and High voltage at the same time. When amp approach 50-75, the battery's internal resistance lowers the delivered voltage, self-limiting the power delivered.
So you crank longer and slower. DC motors pull more amps the slower they turn, less amps the faster they spin. A struggling starter motor pulls max amps, which means max heat. The starter relay has insufficient voltage because the starter is pulling the battery voltage too low because it appears like a dead short. Insufficient contact pressure arcs the contacts and welds them together, so when you let off the key, the starter keeps turning, frying the cables and/or starter while you struggle to disconnect the battery. To sum up Deep cycle batteries struggle to produce the immediate power needed to start a V8. you can get by with a 2-cyle outboard, but not an auto engine (for long) More starters are fried and repalced due to deep cycle batteries in the wrong application. I think an isolator is a diode network that keeps you from pulling you starting battery down when running accessories, but permits charging from one source. |
River Rat to Mole |
Jason
Guest |
When I bought a new battery, I just replaced it with a deep cycle marine battery from wally world. This is not what I should have used?
If I do go buy a regular battery for the boat, can I use the deep cycle with the stereo and have a perko switch. Is it ok to mix batteries? This freakin deep cycle cost me 60 bux. Dont want to not use it. |
GottaSki
Could add a trolling motor
River Rat to Mole |
Marshall
Newbie Joined: September-07-2004 Location: United States Status: Offline Points: 10 |
The jump starters are also nice to have. I keep a small one in my truck and always take it with me on the boat. Do you know how much money you can get for jump on a lonely pond?
'70 Mustang
"Can you hear me now?" |
Jason
Guest |
I dont plan on running my battery down, if we are on the lake, the motor is usually running. However it is more for like a just in case situation, would it work fine for that?
79nautique
Jason it would work fine for a safty net if your dead on the water. There are some deep cycle batteries that have enough CCA to be used as a starter battery. Your battery should be rated for at least 650 CCA (cold cranking amps).
Marshall
I have a 300 amp jump starter and it has started my boat eight times on one charge. Then I decided to buy an alternator. I still keep it on the boat fully charged. Its small, its safe and it works.
'70 Mustang
