  New Posts New Posts RSS Feed - CPES
CPES
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Topic: CPES
    Posted: September-29-2009 at 2:42pm
I am starting to get my list together to do the stringers in my 67 Nautique. This time I plan on using CPES to coat all the fir and ply I am installing. I did a couple searches. I found one reference where Greg said he used most of 2 gallons to do the patch.
Sound about right for what I need to do? I assume I want the Smiths Cold CPES formula considering the temps in my shop in the winter. I used West 105/205 last time for the epoxy and it worked very well.
I found a guy locally that will sell me gallon kits of West Systems for $90. That will save me a ton of dough. He will also sell me my glass tape and cloth at bulk wholesale prices.
My last question is how much will using the CPES reduce the amount of epoxy I need? Last time I coated all the wood with West 2-3 times. I went through a lot on the ply, especially. Will I get away with one coat on top of the CPES coated wood?
Mike
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2009 at 2:59pm
Mike,
With the CPES, figure on 1 less coat of epoxy resin. The 2 gal. sounds correct for the stringers and the ply. It really soaks it in. On the ply edges and lumber ends, you just keep rolling it on, go back in a hour (it's got a long pot life) and apply more!! One good coat on the ply faces will do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2009 at 4:14pm
Perfect.   Thanks Pete, as always!
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2009 at 12:11am
Pete-
I have a few old wood skis here that are partially cracked down the middle. Do you think I can drip the cpes into cracks and fix them? Good idea or bad?
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2009 at 8:58am
Tim,
CPES is designed as a sealer primer. It's viscosity is like water and it won't fill any gaps. The fillers used for epoxys could be used to thicken it up but you'd just be defeating the CPES purpose. Depending on the crack width, a epoxy with a filler probably will be needed. It would still be a good idea to get some CPES in the cracks to prime the wood first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 12:38pm
Tim,
Pete there really is not a gap. It is just a split where the wood was previously joined in the center. In the past normal epoxy has not worked (won't seep in the gap).
Maybe I will get some and give it a try.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2009 at 1:50pm
Tim,
Carefull as the CPES really isn't a adhesive and as stated has no gap filling qualities. Since the epoxy didn't work for you in the past, I'd say it's due to the difficulty in trying to get it down into the crack. I have used wood wedges driven in one end of a crack to open it up and then a epoxy injector (syringe). In some cases, I've even intentionally split a cracked piece all the way to get a adhesive in all the way on the crack.
form&function View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote form&function Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2009 at 7:45pm
The ski needs to be pressed together when you try to glue it.They make a few different types of glue but I just use resin.Don't know why but I have a soft spot for old skis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2009 at 8:46pm
Damn, that is nice!
osukellen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote osukellen Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2009 at 8:47pm
Is that a Maherajah?
Soon to be owner!
Post Options Post Options   Thanks (0) Thanks(0)   Quote form&function Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2009 at 10:03pm
One of the early cypress gardens dp
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2010 at 12:57pm
Does CPES release from plastic like epoxy does?
Or does it not even stick to it in the first place?
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2010 at 1:21pm
Mike,
Depends on the type of plastic but being epoxy thined down with solvent, once the solvent flashes off it acts the same way. It will pop off things like a plastic poly roller tray, plastic poly mixing cups or out of plastic glue syringe/injectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2010 at 1:26pm
Cool. I used blister packs, spinach containers and stuff like that to hold up the pieces from the Mustang while epoxying them. I failed to heed the CPES suggestion on that project, and just epoxied the heck out of the wood.
I should be CPES'ing stringers late next weekend !!
Mike N
1968 Mustang
Waldo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waldo Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2010 at 1:30pm
Slayer you need to get your camera fixed.
Waldo
abolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abolton Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2010 at 7:23pm
3 Questions
Does Home Depot or Lowes carrie CPES ?
Will Polyester Resin stick to the wood if its coated with CPES ?
What makes CPES better than other wood sealers that Home Depot carries like Thompson's ?
ABE
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2010 at 9:48pm
Abe - I'll give this a shot - CPES is a specialty item not used by the general public so I doubt a retail big box store will carry it.
Polyester will not stick to epoxy well - stay with epoxy resin for the entire project. If you really want to use polyester, start with that.
CPES is an epoxy plastic that permanently hardens.   Preservatives like Thompsons are basically an oil based preservative that dries up eventually. Neither epoxy or polyester will stick to a Thompson-soaked peice of wood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-20-2010 at 9:56pm
Originally posted by SNobsessed SNobsessed wrote:
Abe - Igive this a shot - CPES is a specialty item not used by the general public so I doubt a retail big box store will carry it.
Chris,
Well said.
Abe,
I'd only like to add that CPES is really epoxy that has been reduced (thinned) with solvents to a very low viscosity. This allows it to deeply penetrate the wood. BTW, you've been watching too many Thompsons Water Seal ads on TV!! The stuff is nothing but crap!! Take a look at Consumers Reports on the actual testing they did.
