  New Posts New Posts RSS Feed - combing pads
combing pads
barefoot2001 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote barefoot2001 Quote  Post ReplyReply Direct Link To This Post Topic: combing pads
    Posted: April-28-2005 at 3:23am
I own a 84 Nautique. It has no interior pads that run from front to back. I figure it was a option? My question was if they are sold or are usually just made out of plywood and upolstered. Thank you for any thoughts.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2005 at 11:54am
They are made from plywood (1/2", I believe). They are usually held in place by some sort of stud and retainer. If making them myself, I would use blind nuts in the combing pad with a threaded rod (with thread locker to keep the rod from turning in the blind nut) and a washer and nut. You will need a splice in the middle of the combing pad, just make sure you have a stud close to each side of the splice. This way, you do not have to worry about the strength of the splice (factory pads have weak splices).
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote barefoot2001 Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2005 at 1:16am
Thank you for the reply. Thats a good idea, David. The upolstry guy I am going through said if I cut the plywood and install the hangers, he would make them for 245.00. Does that sound decent? Thats with sewing the stripes in too.
