78SN Nidacor Stringer/Floor Rebuild |
Post Reply | Page 12> |
abolton
Groupie Joined: September-07-2005 Location: United States Status: Offline Points: 81 |
Posted: January-10-2010 at 10:48pm |
The dredded cracking of fiberglass allowing water to get into the stringers Looks all orig. too bad have to cut it all out. The Big Dig lots of heavy wet foam, with it gone its just like kicking two fat girls off the boat. Free Hp
ABE
abolton
I supported the hull on jack stands at the transom and keel. Then I built a set up table in the boat to lay out the stringers, cloth and misc. materials - it's worked great for me and saves me from getting in and out so often.
ABE
abolton
I cut the floor out with a skill saw and used a cut off wheel to cut the glass all the way around the old stringer about 1" off the floor. It gave be a nice channel for fool proof placement of the new Nida-Core Structual Honeycomb composit I am using for the secondary stringers. I will use the old floor flange for the new floor to sit on and I won't have to noch out my stringers.You can cut and shape Nida-Core easily its very easy to work with. I use a skill saw to cut and a grinder to shape. The Material www.nidacor.com Butter Up the filit radius for the glass to follow onto the hull with a nice 4" tab.
ABE
abolton
I used a layer of 1-1/2oz mat and another layer of 18oz roving where the double stringer secondary's are and added another layer of mat foward on the single section of the stringers. I will be foaming this area becaus I do not have to worry about any rot with Nida-Core.I am going to foam in a 5/4" x 6" pc of preasure treated board between the two double portion of the secondary grid as a screw block for a larger removable floor panel. Stick it down with a nice 4" step tab of mat, roving and mat.
ABE
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1423 |
Something new thanks for posting keep the pictures coming and great to see another 70's boat rebuilt.
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Getting ready to re-string my 73 skier. What is the price difference between the nidacor vs douglas fir? How was it to work with?
Keegan, You will also need to factor in the cost difference with the extra glass/epoxy needed if the honeycomb material is used for a "sandwich" construction. The extra glass is needed for the strenght loss of not using a strong material for the stringers. I'd say at least twice the glass/epoxy or better is needed putting the cost over the normal wood system. |
Keeganino
Think I will stick to wood then. Would oak be a bad wood? I know Douglas is the wood of choice but my dad has oak planks that he had milled from his land and are well over 15 ft long 2 inches thick and 21 inches wide. It is good wood for most everything else structural, and it would e free to me. Just curious.
Thanks |
Keegan,
The only thing bad about oak is the weight. However, it MUST be White Oak (Quercus alba). Even though a stringer job includes CPES and careful epoxy/glass work, any other variety will rot if it sees any moisture. I'd sure consider the LVL if you can't find the Doug Fir. |
abolton
ABE
Keeganino
Ok thanks I see now in the pictures you left in the main stringers while you did the secondaries. It looks nice and clean! I did look at the website a minute yesterday before I posted to see what it was all about. Very versatile stuff they put out.
Keeganino
I am pretty sure I can get it here in town, but I do not even know what to ask for to even start calling around yet. A restoration contractor I know who specializes in water damage said I should use LVL. He said he had never seen it fail(In houses not boats), and was weary of them when they first came out. I was telling him that it had been discussed on this site quite a bit, but who has done it? I guess for me it would come down to price and difficulty of working with the materials LVL is pretty easy to cut from what I understand from my friend. The nidacor looks nice but if it takes twice the glass that will kill my budget and time frame. Are there any books out there on restringing boats that anybody recommends? I have read so many threads my eyes are popping out. I need a good old fashioned book. "Stringers for dummies" would be great! |
Keegan,
If you call around to a "normal" lumber yard you want to ask for some decent 2x(then width needed) construction in Doug Fir. You will want to be able to had pick some good looking boards. Asking them the moisture content isn't a bad idea ether. It should be about 10% or lower. If you end up having to look for it at more of a specialty/hardwood supplier then you will want to ask for 8/4 if they don't understand the 2x refference. In ether case, a 2x and 8/4 will have a finish thickness of 1&1/2". I'm not aware of any books out there. If there is one then it may even talk about using polyester resin!! Don't!! You best bet is to re read the threads here on the site. |
Bremsen
Senior Member Joined: June-26-2005 Location: United States Status: Offline Points: 171 |
Where in NC are you located? You could always do the floor/foam removal and have Race City do the stringers if you're not up to the task.
*edit, I love how abolton makes his own thread so he's not hijacking another and his thread gets hijacked. |
65 'cuda
I can tell you from experience that cutting a long radius in an LVL is not the easiest task. They are easy to cut with circular saw, but all the glue creates a lot of heat with a reciprocating blade, also the pressure on the blade tends to be one sided while cutting the arc, further heating up that side of the blade creating more tendency for the blade to "walk". Just my .02
Were you trying to use a jig/bayonet saw? That could be the problem as I really don't consider them to be a HD tool nor can you get blades made for the thicker material. A sawsall with a coarse blade (3 or 4 TPI) for roughing shouldn't be a problem and then a power hand planer will go real long way with shaping!! Of course you could also see if a friend has a band saw! |
abolton
Lay up schedule mat/roving/mat/roving 2 layers of each complete encapsulation of a structural core stringer material that will never rot. 1 down 3 to go.
ABE
abolton
The main stringer was an easy pop out and after I cleaned the channel I did a little grind to make it bed ready for dry fit and fool proof placement. On to the Mains
ABE
abolton
Ready to dry fit
ABE
Keeganino
That is nice work! The new pictures will really help me. Just getting started with the demo and am looking forward to being where you are at. Is that a hand planer you used to scribe? Looks like it eats some wood!
1973 Skier |
bkhallpass
"The Fiberglass Boat Repair Manual" by Alan H. Vaitses is not bad. It discusses polyester and epoxy resins, though the author does acknowledge that about 95% of repairs are done with polyester because it is cheaper. I also have a video called "Fiberglass Repair" by a guy named Will Borden. It is about and hour and half long. It's kind of nice to see someone working with the materials. www.fiberglass-repair.com. Both are a few years old but they were recommended to me by DavidF who used to be very active on this site, and was really excellent with fiberglass work. BKH |
Livin' the Dream
Keeganino
Thanks BKH. I will check those out. After reading hundreds of thread pages and some very helpful emails from the guys here, I have learned so much. My thread is Stringer Questions 73 Skier and am showing the world the mess I got into. I am pulling the engine this week and getting it down to the hull as quick as I can!
1973 Skier |
eric lavine
thats the first power planer i have seen on this site, excellent tool
abolton
The Power Planer worked great, it was a big time saver. After I traced the old stringer I rough cut it with my skill saw then power planed it to the line. I rounded the top of the stringer with my router and a 3/4" round over bit for the glass to follow over the top easier. While the old stringer was clamped up to the new one as a template I drilled the hole for the steering cable mount and located the motor mounts points as well. Yesterday I cleaned the channel and did all the grinding needed to get ready for a dry fit and mix up some thickened resin for a 3/4" filet radius at the channel to hull. Then I will use a slurry of waterproof glass fiber filler in the channel and bed the stringer in with one layer of mat on the edge.
ABE
Keeganino
Are going to leave that channel and bed back down into it? Are you still grinding down to the mat? If so do you grind inside the channel and outside to get better adhesion? Leaving the channel like that is attractive to me as I have never been accused of being really accurate,and the guide would make laying the new stringer fool proof. How do you filet it in with the channel there?
Looking Good! |
1973 Skier |
abolton
Yes, I used a cut off wheel to cut the skin all the way around the old stringer, it pops right out with a couple of hits with a hammer and a crow bar. First I cleaned the channel with a steel brush and acidtone then I grind the inside and I feather grind the outside thick at the bottom and thin at the top. To maket the fillet radius, just grind a 3/4" round on a plastic puddy knife and mix up a peanut butter type thickened resin, pull along the channel at the hull to make the fillet. This will ensure not air pockets when you laminate the stringer in. I round over the top of the stringer too, that way the glass gos over the top with out air pockets too.
ABE
WakeSlayer
Pretty much the exact process I am using. The power hand planar is a great tool. I left my channel in and feathered just like you are describing.
Mike N
1968 Mustang |
storm34
hey eagle, whats Mr. Franken's opinion on flotation foam?
abolton
I like the flotation foam only beacuse where I do my boating I can get swamped by the occational 50' Sea Ray. BUT I am only putting the foam cavities next to the Nida-core composit secondary stringers and in the bow in front of the kick plate. I am also up-grading the bilge pump from 500gph to 2-1,000gph one in the orig. location with 1-1/8" hose and thru hull and I am adding another in the stern that can auto pump out while on plane. I have taken a lot of water over the windshied on the hot days and kinda supprised the water logged foam still worked for me - been lucky!
ABE
abolton
First Main made and bed in
ABE
