oil filter |
82wake2001
Senior Member Joined: February-14-2008 Location: United States Status: Offline Points: 240 |
Posted: April-01-2010 at 5:41pm |
good afternoon...
Could someone tell me what oil filter I need to grab. I am trying to avoid driving out to my boat then coming back into town tonight when I change my oil. I know to stay away from fram, but forget the size.... |
Joe
1982 ski nautique 2001 "Lady of the Wake" |
82wake2001
Oh yes I have a 1982 ski nautique with a PCM 351 engine...
Joe
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21185 |
Motorcraft FL1A (available at Walmart)
Napa 51515 |
82wake2001
Thank you very much.....
Joe
Tim,
You forgot to say don't get a Fram!! |
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
The AC is Blue and matches the motor color pretty close.
Do not remember the number. |
1980 Ski Nautique
1966 Barracuda |
YooperSully
Senior Member Joined: August-07-2009 Location: Hancock,MI Status: Offline Points: 316 |
NEVER FRAM IT!!!! Last fall i was bored so I started to research oil filters. I always thought Fram was a good brand. Surprising enough, Fram is one of the worst. Cheap cardboard caps on the filter ends and some other cheap stuff I can't remember at the time. The filters that walmart carries, pro-tech 2000 or something like that come in a couple better than Fram. After the research, I ended up choosing K&N HP3001.
87' 2001
Keuka
Senior Member Joined: October-15-2009 Location: Keuka Lake, NY Status: Offline Points: 162 |
Motorcraft also make a FL-1-HP that is recommended for high performance and severe use vehicles. I think the RPMs that are run in a boat would put it the severe use catagory. It is interchangeable with the FL-1-A put you can really tell the difference just picking it up. It is much heavier. I ran these in the 429CJ Torino that I used to have.
David |
86 Martinique
Does anyone remember that web site that the guy cut open all those filters and compaired them? I tried to search but could not find it.
bbialik
Newbie Joined: February-15-2010 Location: United States Status: Offline Points: 3 |
Does this look familiar? Oil Filters Revealed |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Speaking of filters;
Last Sunday I was heading to my shop in my 2007 Avalanche, when I got a warning on the cluster that I had NO oil pressure. The gauge was at ZERO. I pulled off the road and shut her down. After waiting 5 minutes, I started it up. The gauge went to 20, and back to zero. I had it towed to my shop. We did an oil change (which it was not due for), and to my surprise, I saw the smallest oil filter that I've ever seen on a car or truck. It measured 3" dia and 3" in length. We cut the filter open (it was a Valvoline, from the quick lube joint) and it had quite a bit of crap on the bottom of the can. It makes me wonder if they actually changed the filter on the last oil change. The truck is running fine after the oil change. I'm fortunate that it didn't happen after using the remote start. I wonder if it would shut itself down? I'm going to start changing filters after 2000 miles, half way between oil changes. |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
That's it Blake, thanks
82wake2001
well oil is changed and plugs are replace.....however the boat is trapped on the clutches of the wet yard... :( |
Joe
79nautique
There usually is an optional filter that is longer for GM applications like yours. |
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
Nice looking boat Joe..
What is wrong with Fram!? I don not use them, but are they that bad.. |
1985 CC 2001-SOLD
Lee Michael Johnson |
82wake2001
Thanks Skicat....
well she is out.... i am starting to think it is time for a carb rebuild.... |
Joe
skicat2001
No problem Joe.. Is the boat running bad? Have you put here in the water yet.. Watched the weather channel, you guys are getting some great weather up north and in the east.. It is in the mid 80's today in some places.. |
1985 CC 2001-SOLD
82wake2001
well i checked the gap on the old plugs which happened to be NGK's and they were are .55....so the new ones are set at .35 and are autolights...
plus i am on the first tank of gas for the season... |
Joe
