Voltage drop |
TheChad1976
Groupie Joined: October-12-2009 Location: Jacksonville FL Status: Offline Points: 44 |
Posted: May-27-2010 at 7:28pm |
Just curious if anyone else has had this issue.. I just bought a brand new "starting" battery not a deep cycle because the old one seemed to be getting weak and slow starts at the beginning of the day. Now this new one starts great but the voltage wont read over 12 when its running and if you have say the blower running it drops down to 10 on the meter. The old battery would read about 13 when running and 12 with acc's on. Does anyone know what would cause this voltage drop? Oh and if you turn the lights on also its game over. The meter reads around 8 or 9. The wired part is the batt never seems to have any issues starting the boat even after I have had the stereo on for a while without the boat running.
eric lavine
a fully charged battery will show 12.69, while running you should be seeing a minimum of 13.00 volts unless you are having alternator problems. it may be charging but not at potential, check all of your connections especially grounds, once distrubed something may have come loose......98% of ALL electrical problems are connection related
skicat2001
Platinum Member Joined: November-24-2008 Location: Ft. Worth TX Status: Offline Points: 1950 |
Hey Chad,
Eric got you on this one. Check all your connections and roll from there. Mine shows 13 when rolling, and If I turn a switch on or something volts will drop a little but return back too always 13. What kinda battery did you buy? I really like the battery I have, Car Quest Marine battery with the 850 CCA.. Works great.. |
1985 CC 2001-SOLD
Lee Michael Johnson |
TheChad1976
Its a Energizer Marine Starting Battery with 500 CCA I believe. The one that was in there before was just a cheap car battery. I am going to grab a Voltmeter and clip it strait on to the battery this weekend and see what it does at the battery level. I would think that should tell me if its and alternator issue or not. The thing that is really confusing to me is that the old car battery seemed to do better than the Brand New Marine Battery.
skicat2001
I dont want to shoot you wrong but I dont know if the volt meter will tell if you have a bad alternator. I am sure there is a tool that will do so.
The car battery worked better huh.. Wow! Maybe you do have a bad alternator. |
1985 CC 2001-SOLD
TheChad1976
I want to see if I am getting a "true" reading on the dash guage as compared to the what the battery is really putting out. I would think if I dont get around 13 volts directly at the battery when running then that would indicate the alternator isn't charging properly.
skicat2001
Hey Chad,
I bet you right. Maybe you pulling a different volt than shown on the dash. My guess is that marine battery is good you got, but the altanator is not charging it properly. |
1985 CC 2001-SOLD
two0426
Newbie Joined: May-17-2010 Status: Offline Points: 5 |
Chinese online game users, the annual per capita consumption of 40,000,000 nearly 75 U.S. wedding dresses wow power leveling wow gold aion gold wow power leveling wedding dresses nearly 75 U.S. games, and both figures are still growing, the future of the Chinese game Market has great potential. 28 am, the fourth game of the International vvkkslaopzxzxz Conference on Research and Development in Beijing, Zhou served as full-Executive Chairman of the General Assembly. aion gold Game of the International Conference on Research and Development is an international computer games industry high-level conference, an annual event. This is the first General Assembly held in China. wow power leveling Said Zhou Ming, the Chinese game industry research and the rapid development of the game, but the games market in research and development, distribution, training, and so are not yet ripe for supporting the game industry's lack of core technologies, the need for the further development of computer graphics technology, virtual reality technology, Software engineering technology to create an wow gold independent integrity of the online games industry chain.He said that the General Assembly of the game at home and abroad to strengthen personnel exchanges, but also to the Chinese game industry's development and progress brought about a turning rolex point, China will promote the game industry's core technology research and development. Hall meeting, the participating companies have displayed their latest achievements. Philips 42-inch display three-dimensional bring real three-dimensional effect, as the Code in the number of new Replica Handbags scientific and technological research and development of a physics engine system in virtual reality simulation of the collision scene, inertia, broken, such as the explosion. It is reported that the General Assembly will last two days 0531 LJ.
form&function
Senior Member Joined: August-21-2009 Location: OK Status: Offline Points: 342 |
My gauge reads just over eleven but at the battery its thirteen.turns out from the factory the entire boat runs off one small power wire causing a drop at the dash anytime you use anything.
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
I clean all my connections and had some luck but not much when I turnned on the blower etc. Also do you think 500cca amps is enough ? I run 850
powerslake80nautique
Newbie Joined: May-31-2010 Location: powerslake wi Status: Offline Points: 5 |
If you can pull negative terminal when boatis running, if boat stays running alternator is good if boat dies alternator is bad
kapla
you are rigth on the problem.. mine acts like that also..poor dash power... at the battery or alt it shows 13.. dash 11... when I turn the lights all gauges get wacked...voltage drops..and the Tº raises 10º |
<a href="">1992 ski nautique
skicat2001
Yea, when I am running no other dash buttons , I pull 13. If say I am just idling and may turn the blower on, or nav lights volts drop to 12 or 12.5.. Soon as turn a switch off, volts go back up to 13.
1985 CC 2001-SOLD
srbranum
Senior Member Joined: March-06-2010 Location: Huntsville, Al Status: Offline Points: 376 |
I had a problem with my alternator not charging last year. The first thing I did was blame the battery or alternator. We tried everything. Guess what it was? The belts were worn and were not gripping the pulleys like new ones and thus were slipping and not charging. Don't know if this would help but you may want to look in to it.
scott |
I have to keep her running 'cause I can't afford a new one
TheChad1976
Ok so after a weekend of running the boat for 3 days pretty hard, I connected a votlage guage strait to the battery in addition to the one on my dash. The guage that was connected to the battery stayed where it was supposed to and pretty steady around 13volts, however the one on the dash would drop tremendously when the accessories were turned on. At one point I was using the running lights and the blower and it was reading around 8 volts on dash but the battery stayed around 13 still. I guess this is just something i will have to deal with unless I want to run a whole new electric system strait from the battery with a new fuse pannel and switches.
TheChad1976
Oh and one other thing I noticed is that when I turn on the running lights all of the guages are way off and do some crazy things.
Sounds like a bad ground,you should find them all and clean them starting under the dash
