  New Posts New Posts RSS Feed - What causes excessive Blow By
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Topic: What causes excessive Blow By
    Posted: September-07-2010 at 11:12am
Our Mustang engine runs good. We've put about 20 hours on it. It has never been rebuilt or had a valve job to my knowledge. It doesn't use oil or smoke. When running along at speed it gives off a Blow By smell that gets stronger the faster you go. At idle it doesn't give off any fumes. It has a vacuum tube running from the engine to the base of the carb and the oil cap is vented. What causes an engine to do this?
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2010 at 12:06pm
heh, the engine is not broken in yet.
If you don't witness vapor from the oil cap, then it could be as simple as a small oil leak from a valve cover gasket, onto the exhaust manifold.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2010 at 2:33pm
Any chance it's exhaust smell, not oil? You could have a small leak from the exhaust manifold gasket or hose and it might give you that smell. I'm not sure why, at speed, you smell anything with the breeze going by! I have that exhaust smell following me at just below planing speed but it goes away with a few more mph.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2010 at 3:01pm
I'll try checking for an exhaust leak and tighten down the valve cover. I never thought of that. It smarts your eyes and burns your throat afetr a while.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2010 at 3:13pm
I believe the when the ventalation is inadequate, the cockpit with windshield creates a low pressure area that pulls air from the bilge up and dumps it by your feet and swirls around.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2010 at 3:13pm
My ventilation setup (or lack of) is interesting. There is no bow vent, no stern vents, nothing. The floorboards have a gap around the edge. The former owner said the idea is the engine pulls air from the motorbox, the make-up air flows all around the bilge keeping fumes from collecting. It seems to work, I've never smelled anything from the engine. That's why I'm surprised you could smell this so strongly with the boat moving fast, you'd think there would be enough air flow.
Because of this, and no blower, I open the box for a few minutes before 1st startup, good idea anyway to look over everything.
