  New Posts New Posts RSS Feed - battery connections
battery connections
tpr471 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote tpr471 Quote  Post ReplyReply Direct Link To This Post Topic: battery connections
    Posted: June-28-2005 at 2:09am
I'm getting ready to replace my battery cables on my 82 SN. My question is most marine batteries have both type of connectors. The clamp type and the bolt/wing nut type. Can you use the bolt/wing nut instead of the clamp as it is now using?
Tom View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2005 at 10:48am
EVERY outboard motor manufacturer supplies cables for the wingnut posts with their new motors... Nearly every inboard I have seen during my last 2.5yrs in the marine repair business uses the wingnut posts as well.
I will offer this advice, get the tin plated copper terminal ends and true "marine grade" battery cables (tinned wire, more strands, better insulation, more flexible) and you can make your own cables at home that are WAY better than what you can purchase.
DO NOT use the wingnuts supplied with your marine battery; replace them with 5/16" or 3/8" locking nuts and tighten them with a wrench. 50% to 80% of all the 'dead battery' and 'won't start' problems we see at the shop are attributed to loose battery connections where some pansy has barely tightened those wingnuts and the connection, all though it will run the radio, horn, lights, and register on the boat's voltmeter, it CAN'T conduct the couple hundred amps required to crank the engine.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2005 at 12:55pm
Here is my oppinion:
Those marine batteries with both studs and posts are duel purpose cranking and deep cycle batteries. The studs are used for trolling motors and the posts are used for cranking the engine. Duel purpose batteries are a compromise to both in my oppinion.
I suggest (next time) you forget the marine battery route and buy a good quality automotive grade cranking battery. You will save a bundle.
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2005 at 2:16pm
I am with David here...Those wingnuts type connections are trouble. I use a group 31 automotive type battery with 3/8 studs for posts, then SOLDER not crimp 3/8 eyelets on the cables mounted with stainless lock nuts. Same battery and no connection issues for almost 3 years. Just a little extra $$ and a little more efort in this aera will save you a big headache out on the water.
NO LONGER A MEMBER
Keith View Drop Down
Admin Group
Admin Group
Owner / Operator of CorrectCraftFan.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2005 at 1:35pm
Any one know the approx. length of the cables (+ and -)? Need to have some made today and don't know the lenght off hand - they are for an 86 Nautique.
I have to think the neg. should be about 6 feetand the positive about 8 feet. Can anyone confirm?
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2005 at 3:39pm
I think I got 7 and 9 cables for mine. wanted a little extra for easy routing.
