  New Posts New Posts RSS Feed - vent tubing opinions
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Topic: vent tubing opinions
    Posted: September-28-2010 at 6:25pm
I discovered the vent tubing in the bow of my boat was shot. One somewhat functional, one crushed, one split in half. I did some dumpster diving and found some 1-1/2 ridgid corrogatged tubing that I put in its place. The diameter is smaller meaning less airflow but the ridgid walls should offer less resisance and should increased flow. I know I am way ahead of where I was, and this stuff will last forever compared the the stuff that was in there. Think this is enough flow?
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:29pm
If youre worried about the decreased diameter, dont be. Remember, the stuff below your floor is the same crappy stuff and is probably rotted, split and crushed worse than the sections you replaced... so youre definitely no worse off!
If you were replacing the whole thing, then sticking with at least 2.5" (3" is optimal) would be better, though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:40pm
I replaced the one to the bilge blower in back with 3" aluminum drier duct. I have no idea what it looks like underneath but I suspect the front ones were was damaged by skis and vests, I hope they are intact under the floor.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:43pm
...And maybe they are. Or, maybe they've disintegrated or been crushed by waterlogged foam like the ones Ive found. Theres one easy way to find out if youre curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:47pm
Cant I just stay blissfully ignorant and feel ggod about what I did for a day? Ok how do I check.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 6:56pm
Ha, Im just giving you a hard time. Even if torn or rotten, the paths for air to get to the engine compartment are likely still in tact- so dont give it much thought. Im sure you can imagine what it would take to inspect that area under the floor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 7:00pm
Fiber optic camera, Kind of a cc colonoscopy.
1987 Ski Nautique
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2010 at 7:09pm
More like cutting open the floor, but I like the fiber optic camera idea!
1973 Skier
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2010 at 10:59am
Ha. Easy in the sense of "not complex". Man, I hate digging foam.
Mike N
1968 Mustang
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2010 at 5:07pm
There are the pre '94 owners that have, and there are the pre '94 owners that will... Unfortunately, I'm still in the second group!
- Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2010 at 5:39pm
Not to be argumentative but 1993 was the first year CC switched to composite stringers. Don't want to hurt ANY '93 owners' feelings. Other than that, a very true statement!
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2010 at 8:31pm
Oops, mixed up the years again... My bad!!
So I'll rephrase: there are the pre '93 owners that have and there are the pre '93 owners that will...
(and unfortunatly I'm still in the second group, even after the rephrasing ).
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2010 at 8:48am
water still gets down in the post 93's, freezes and seperates.....but that will be another discussion in a few more years   lol
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2010 at 9:15am
FWIW-The vents under the floor in mine were completely blocked, crushed, clogged, and a few more things that escape me now. The first couple of years I had it, it must've been breathing bacerds...from under the gas tank.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2010 at 1:43am
Too true. I wish I had a climate controlled space to store my boat.
1973 Skier
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: October-02-2010 at 4:53am
There's a name for that space - California. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2010 at 12:32am
I would live there in a second! Love Socal!
1973 Skier
