  New Posts New Posts RSS Feed - Truck front end
Truck front end
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Topic: Truck front end
    Posted: October-10-2010 at 11:39am
98 2500 dodge diesel. Needed to do the front brakes, so I hit all the grease fittings and rotated the tires.
BUT the brakes, geeees I retracked the caliper pistons with a C clamp. They moved easily stayed about an 1/8 from flush. No way would they the caliper slip back over the rotor with the new pads. I ended up sanding the inside pad for about 15 sec. on a belt sander. I did one side at a time, both had to be sanded. Also the wheel beaerings had no play at all. I repacked the bearings and set the bearings (while rotating the rotor) then backed off the nut .010-.015 Test drives 4.0 The pads are NAPA primium semi matalic. Iv'e done a few brake jobs but never had this happen.
- waterdog -
78 Ski Tique
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2010 at 9:33am
to reassure you, I have done it in the past also
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2010 at 12:54pm
Andy, off the topic of brakes but on the topic of Dodge diesels, are you running any supplements in your fuel to off-set the reduced sulfur? I have an '02. I've read some guys are adding 2-cycle oil, others are adding ATF. Do you have any personal experience with this issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2010 at 5:45pm
Terp,
I looked far and wide to get this truck. It has a full machanical P7100 fuel pump Cummins used it from 94-98 It will pump french fry oil if you heat it to 140*f My bro in law is the Cummins mech @ Hill/Kelly Dodge in Pcola, Fl. I give him a call on my way home & see what he thinks.
- waterdog -
78 Ski Tique
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2010 at 5:50pm
OOOH    the grail truck!   I have a 93, but would be curious about supplements too.   gotta love a good truck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2010 at 6:20pm
off highway? high in sulpher, no taxes, illegal to use...but cheating is legal unless your caught...know a guy who runs it and took the badges off the back of the car, TDI
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2010 at 9:47pm
Andy, I sure appreciate it. I had the boost pump replaced (on the Dodge mechanic's recommendation) in the spring b/c it was bogging intermittantly when asked to accelerate. The problem persisted and now they're saying to replace the inj. pump ("sometimes it gets damaged when the boost pump fails to supply proper pressure") $1700 just for the pump. I wondered how much the new fuel might have played a role in it. I had been using off-road diesel until about 18 months ago. I came across the 2-stroke/diesel mix in a JDeere publication last month. There are mixed reviews of the practice on the Cummins & Diesel forums. Of course the Dodge dealer has no comment. I did run a tank w/ Marvel mixed and the problem seemed significantly reduced. Then I ran a tank w/ Power Service mixed and it was much worse. So I just refilled w/ Marvel mixed again to see if it improves again. Is this mechanical pump you are speaking of applicable to the old style 2002s? Is it better than the stock pump on a 2002?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2010 at 10:53pm
Terp, In the second half of 98 Cummins changed to electronic fuel inj. and the 24 valve engine to keep up with the EPA. Your pump is about softball size mine looks like a small 4 cyl engine. My engine doesen't have any electronic controls. I'm playing phone tag w/my bro in law.
Google Pensacola Diesel for parts they may save you some cash.
And I'll try catch up with my bro in law he's a BIG bow hunter and might be in Alabama in a tree stand!
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2010 at 1:54pm
Trep, This is the story. 98-04 the lift pump is a pull thru pump on the block. The fuel strainer in the tank gets stopped up (with algae / debris) the pump gets starved for fuel but still runs OK till it fails. Harvey said the fuel additives and or the low sulfer fuel didn't cause the failure.
Dodge has a revision kit with a push thru pump mounted in the tank to take care of the problem. If the pull thru pump was replaced with another pull thru pump on the block the problem is still there and the VP 44 electronic fuel injection pump is the next thing to fail. He said if the work was done at a Dodge Dealer they should have known that.
I also change the fuel filter every other oil change.
- waterdog -
78 Ski Tique
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2010 at 6:36pm
Thanks Andy. I'm really aggravated to think this job wasn't done properly. They certainly did not explain it that way when they did the job. I'll have to sort that out w/ them.
My fuel pump issues aside, did you two happen to discuss any of the various fuel supplements and what his thoughts were on them in general?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2010 at 9:04pm
Terp,
The off highway fuel is not as filtered / refined as the on highway stuff and the electronic controled fuel pumps are fussie. I would'nt chance it. My man thinks most additives do no harm but don't do a hole lot ether. I like stuff called Sea Foam to keep the injectors clean and thats what the dealer(stealer)peddles.(I do think it works)
   In the last week fuel jumped 25 cents here from 2.80 to 3.05 a gal. Its more common and easier to refine than gas so WTF!
I'd like to put a 4 in exhaust on mine and maybe a fuel plate to add power / fuel. He asked about my mileage. I said, the last time I checked it running mostly 1700 rpm/62 mph back and forth to work - 26 mpg, over 700 miles between fill ups. He just sat on the phone! My trucks empty weight is 8800 lbs. and dosen't start to snort till GVW is 25,000 lbs. then the mileage goes down hill FAST!!!
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 10:59am
the off highway goes thru 95% electronics on heavy equipment, boats also use off highway and avoid the taxes, im just curious if there is evidence to back up the statement on the refining process, typically the filtering systems on a diesel are 10 fold than on a gasser and of the cartridge type...even seen some that used a roll of toilet paper in a cartridge.
really though, highway driving at 80 mph and city driving im seeing 500 miles on 12 gallons. I would bet if i hopped on the freeway and set it at 65, i would easily see 50 mpg. not to bring up politics but if it was mandated and laws passed and everyone was required to purchase a diesel car, we would cut fuel consumption in this country in more than half. the biggest problem I have with convincing people that diesel is the way to go is the cost of diesel, because it is typically .40 more a gallon they think it costs more to operate...they cant figure in the mileage lol.
I told you guys one time a guy told me his son in law locked himself in the garage and fired up his powerstroke, got him sick but didnt kill him. one other advantage is the flashpoint of diesel, you roll it over on the freeway and your not going to explode so you can sit there waiting for the ambulance still buckled in and not worry lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 11:06am
btw, the old man was pissed it didnt kill em
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 11:46am
HS you're doing something right! I'm lucky to run 16.5 on mostly highway driving, although I'm typically running about 72 @ around 2k up & down mountains. I might get it into the 19 range if I kept my speed down. Around the farm and pulling the boat back and forth to the lake it will hang around 12.
I added a 4" exhaust several years back, out of neccessity more than anything. The stock exhaust rusted out and the 4" aftermarket was much cheaper than the OEM crap that didn't last but a couple of years. Seriously, I think it was about 30K miles if I remember correctly. I have had more corrosion issues w/ this truck. I've noticed no improvement/difference w/ the 4" but didn't really expect to, having done nothing else to tweak it. Oh, there was one improvement, it hasn't rusted out after 30K.
I wondered once or twice in the past if there might be a difference in the way the off-road diesel was filtered but figured if I stayed on top of my fuel filter changes (which I do) it shouldn't be a problem. I only quit using it b/c I heard the MSP was stepping up enforcement on it.
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 12:08pm
Was it a Fram?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 12:12pm
no charmin lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 12:32pm
Eric your killing me- If diesels were mandated I'd quit driving.I had one and I know it was along time ago and that they changed. BUT for the past 31 years my commute is 7 miles.My diesel never warmed up and at 100K the motor was worn out.They are not for everyone.It was a big mistake,it will never happen again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 12:54pm
Eric, Just to make hiway diesel "Ultra Low Sulfer" takes more refining. I hear the new Charmin filters down to 3 microns.
GaryS,In the US we are going green different than Europe. Diesel is the future on the other side of the pond. The VW TDI racing series over here is pretty cool.
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 1:06pm
Andy you pushed the magic button.Im the same age as you,only drove VW's for many, many years. THAT company will Never get another nickle from me ever again for various reasons no matter how good their cars may get.
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 2:35pm
I won't mess w/ diesel again either. I thought I would need the power around the farm. I recalled the last time we had a fuel "crisis" and the truckers "revolted." Diesel price came down, gas price went up. I thought I might have some leverage there. Wrong on both accounts. What I did get was extra hassle treating the fuel for cold weather and keeping the damned thing pulled in all winter.
*FOR SALE* 2002 Dodge 2500 Regular cab diesel....Oh! Am I in the wrong forum?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 3:25pm
dont worry boys, you'll be plugging something in.whether its electric or diesel.
Gary we adapt, my drive to and from is all freeway but again i warm the car up 15 minutes early regardless of the temp outside.
I said I would never get married again....but i did lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2010 at 4:25pm
Your right Eric,if thats all we have,I'd be driving it.You bring up a good point tho,I could plug it in at home but at work, forget it and thats where I'd be stuck.I made me dissapointed with the fact I paid more for it,delt with the hassels of finding fuel and reeking of it when I did find it and then all said and done for my efforts of trying to do good got to pay same license fee's as a gas hog and get jacked around with diesel fuel taxes
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2010 at 11:22am
we'll see what happens this winter, not to bad so far finding fuel. it is nice though going 500 miles before putting fuel in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2010 at 12:13pm
I had twin tanks in my VW and carried 20 gallons.The few times I drove it on vacation,I could make the Florida border from NW Chicago with out stopping for fuel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2010 at 11:26pm
Terp,    the emissions gear was supposed to play havoc with the fuel mileage, as was the upgrade from 5.9L to 6.5?   which motor do you have? My 93 with the 5.9L gets 22 mpg all day long, 25 if Im on the freeway, and about 17 if I'm towing. I max out at about 65 though... One really good thing about the later versions was that you could hit 70 if you wanted too . the Gale Banks turbo, intercooler and exhaust helped the MPG's out quiet a bit, and didn't hurt in the power dept.... might be worth a try if you wanted to add some economy and ponies at the same time.    Waterdog - our diesel is 3.55 gal and has been over 3.00 for the last 4 months... I'd love to fill up at your rates!
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2010 at 1:05am
24V 5.9L Has averaged mid 16 since day one. On a long haul I can get to 19. That's the computer readout. I've never calculated it out myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2010 at 10:11am
Gary, did you stop to pee?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2010 at 10:52am
Trep, There are 2 rear gears 4.11 & 3.55 for the dyna 70. The tag under the hood on yours might say 4.11.
- waterdog -
78 Ski Tique
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2010 at 7:27pm
Andy, it's a 3.55. I didn't think about that when talking MPG differences. I've always been hesitant to mess w/ aftermarket mods. Banks does seem to have a good rep and I did briefly toy with the idea of investing in some of their mods. I still get their e-mails on a fairly regular basis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2010 at 9:24pm
mods may be worth checking out if you plan on keeping your truck for a while.... Banks is reputable, as are a couple of the others... I am surprised that your mileage is so much lower, mine is only 2wd though. I think my dana 70 has the 4:11 gears. It pulls like crazy, just not very fast.   I looked at getting them changed when the rear end was rebuilt, but got talked out of it because of the pulling power loss. not sure if that was a good choice or not, as I drive empty far more than I pull... up to 250K on the clock, and I hope for another 250k before the body falls apart
