wiring diagram 1994 5.8 pcm pro boss |
ederaaff
Guest |
Posted: July-14-2005 at 6:34am |
Can anyone help me with a wiring diagram of a 1994 ski nautique with 5,8 ford pro boss engine with electronic ignition.
If you want to see a picture of our nautique look at: www.skydolls.nl under "de boot". We are a dutch waterskiclub and have some problems with the ignition. When I put power directly on the ignition unit it works OK. If I use the existing cable the engine is strubbling at low rpm tryiing to accelerate. Then after approx 2200 rpm it going ok. I think this comes because of a cable problem and I want to replace a couple of cables. That's the reason I'm looking for a good wiring diagram. If anyone be soo kind he can also fax it to: +31 78 6201 100 With my name on it. THANKS from a dutch ski nautique fan!!! |
