  New Posts New Posts RSS Feed - Gelcoat Repair
Gelcoat Repair
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Topic: Gelcoat Repair
    Posted: March-01-2011 at 7:11pm
I have been reading about gelcoat repair for a week now and was trying to avoid another gelcoat thread but alas I still have questions.
When do I use a filler instead of just applying gel? Or rather how deep does it need to be before gelcoat alone is not going to fill the void. I have a few spots that are down to the bare glass. Will the gel alone fill this kind of void?
Any suggestions on tinting the pure white gel to try and match the aged white on the deck?
I have all of my rubrails off right now and am polishing them and I want to get these spots right next to the rail fixed before I put them back on.
Looking at ordering gel in the next couple of days. US composites seems to have the best prices out there. Any suggestions on brands? Also which filler is best?
Thanks I will post pics as I go.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2011 at 11:47pm
Originally posted by DrCC DrCC wrote:
Different brands and colors cure and polish out differently.
Usually whites and light colors polish darker. The amount of hardener will also effect the color.   An exact perfect match usually involves a lot of sampling. Also a filler in gel coat will not finish-out very well.
More hardener makes it darker?
By filler I mean under or before the gelcoat- like bondo. Not an additive to the actual gelcoat.
I think I am just going to pick up a tube of evercoat at the local marina and give it a shot. I have several spots to repair which is the only reason I was considering getting a quart from USC. About the same price as a 1oz kit at the marina that comes with all the colors I dont need.
1973 Skier
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2011 at 11:59pm
Yes, Too much hardener.
Those little spots, I wouldn't use any filler.
To match yours, you'll need a touch of yellow, brown and sometimes also green, blue or red.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 12:03am
My '74 for example,   Takes white with a very little caramel (yellow and brown) with an ever so slight hint of green.
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 10:23am
I am going to try the to fix mine as well, Do not forget the waxing agent. for sanding I ordered the neutral from Us composites and am going to try a little of try halyard or off white, Unfortunately I ordered a quart of the neutral and they sent a quart of halyard. So if you need some I could send Since I have so much if I get some time I will mix it up. My boat is what they call taffy, creme and as aged lighter. Looks very similar to yours.
Lakedog55
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 7:13pm
While tinting to match, start tinting with just a teaspoon or tablespoon (small amount) of white.   Then use that to color your batch.
Tinting the whole batch with straight pigment can go horribly wrong very quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 8:02pm
Dr thanks for the tips. DO you suggest starting with white or starting with neutral and mixing to color?
Guess I need to wait for a warmer day since it is in the upper 50's low 60's right now. Will keep sanding and polishing my rub rails. Got one partially buffed and it looks great.
Thanks for the offer lakedog. Still need to look up that color.
1973 Skier
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 9:10pm
I've never used a neutral.   I've always started with the pure white.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 10:40pm
Keegan,
Check out Mini-Craft of Florida. They have a spray repair kit.
FYI,
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 10:53pm
Don't bother with minicraft matching Keegan.They won't be able to match it in their quarts let alone in a spray.I used them for my gelcoat,but with 40 year old boats,you will have to match it yourself.I got their color wheel picked a color that was close,and got it the rest of the way myself.You need to come to sjrr.Sneek away,play hooky,call in sick what ever you have to do,I'll show you how I did mine.I'll bring the color wheel see you there
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 10:57pm
Gary,
Please bring your color wheel. I will be at the SJRR and I would like you to show me how you did it.
Thanks,
Donald
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 11:25pm
Gary I wish that I could make the river run but we have had our Spring Break trip to Baldhead Island planned for a year that is gonna eat up all of our time off.
I want to get the chips done around the rub rail before they go back on
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 11:29pm
Will do Don,I'll put it in the boat right now so I don't forget!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2011 at 11:35pm
Keegan what color did Correct Craft call your deck? Mine is Taffy Ivory as per the brochure.Check yours and let me know,I might be able to help you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 12:17am
The deck is listed as "Pure White". Sounds so easy!
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 12:29am
Sorry than Keegan it will be way off.You will be surprised of how many "whites" there are.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 12:38am
For you guys that are going to SJRR, take your cameras.   I really like all the great photos of the crystal clear waters of the Silver Glen Springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 3:15pm
you guys are going to be in silver glenn , thats about 30 minutes from my house I wish I was done
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 3:21pm
You guys can also put in at the Ocala boat basin and idle up the silver river which leads to silver springs Aka Glass bottom boats, It also connects to the Ocklawaha which runs to the chain of lakes to the south and all the way to Jax, But I would want to find out the condition of the river before getting to crazy out there, It is very scenic. Easy to get lost lots of branches that start off looking just like the river only to lead to nowhere but minus a few beers it is pretty simple to navigate.
Lakedog55
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 4:15pm
Here's a link to the 2010 St.Johns River Run.   Photos begin on page 9.
2010 SJRR
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-03-2011 at 6:03pm
Gary, I need to talk to you, I have the taffy gel and am planning on doing a little repair work this spring. If yours is a match for mine I'd gladly pay you for a bit of it.
email me your Phone # please
