  New Posts New Posts RSS Feed - Ford 351 with PCM manifold heating up while idling
ZenZeus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Topic: Ford 351 with PCM manifold heating up while idling
    Posted: March-10-2011 at 2:33am
Hi all,
Well I can't wait to show you my 6 year restoration project on my 77' ski nautique. Will post pics in week or 2.
Before I get to problem - The long block, intake and all engine components are brand new. the boat was just started for the first time last weekend. I put a FWC system on it. New hoses - everything.
(I bought these 96' PCM manifolds and risers used - looked good from surface)
I am using a proflo system to flush boat on trailer. Plenty of water is flowing out the flappers equally on both sides. Raw water pump is new with new impeller.
The motor starts up fine. The motor idles fine. The intake, heads, valves and riser elbows are is cool to touch. The heat exchange is cool and warm right at thermo - like it should be.
After about 3-5 minutes I notice steam coming from the driver's side manifold. Really hot to the touch along the bottom especially- although the elbow and riser is not hot. The other side is cool.
Both heads are warm to touch and feel to be the same temp. Nothing alarming there.
I need some help. I don't want to jeapordize the new motor.
I read a few things on various forums. here are some of those:
- gasket on riser could be facing wrong way - no, mine has tab to rear.
- maybe my engine doesn't reach operating temperature when in idle.
It could be that when your thermostat is closed only 1 side of the exhaust get enough water (the cold side) and the other side get less - lots of water pouring out back on both sides so thinking something else.
- a guy mentioned that could be just hot at idle and higher revs will provide more flow pressure and work just fine - I am not comfortable with that.
- There is also a flapper on the inside of some of the exhaust manifolds that can stick in the closed position and cause this problem - I am thinking this may be the cause.
How do I know if manifold is bad?
Can I run some test on the manifold somehow somehow?
Problem 2:
Not sure about my temp sending unit (new too) / temp gauge - .
When I turn the key from a cold start the temp meter reads 190-200. As it idles the temp creeps up to 240 however the motor, block, intake, heat exchanger, valves and heads are barley warm not even hot -
So Im think something is up with temp unit or gauge. I am not sure how a cold motor can read 200 at start up.
Anyone got any suggestions for me? I sure could use some.
Thank you very much,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 2:34am
Oh, its a ford 351 escort reverse rotation
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 8:59am
Mark,
Welcome to CCfan. With all the skilled tech help here, I know we can help. Heat exchanger? Do you have a fresh water cooling system?
When you got the new temp sender, did you match the Ohm range to the old gauge? Post some pictures showing the routing of the cooling system (hoses).
Make sure you get the pictures posted!!!
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 9:45am
Pete, maybe he is refering to his trans cooler?
pictures are important
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 9:48am
what is the condition of your RWP, it could be pulling air thru the seal or weep hole. airiated water completely looses its ability to transfer heat
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 2:15pm
Thank you guys for responding.
FWC system - yes from monitor. brand new.
All new hoses throughout motor
RWP is rebuilt with new impeller.
Upon speaking with Ski DIM, rich said I had an automotive temp sending unit. I just checked out the woring by grounding it and it pegged the gauge to hot. Getting new one today.
Rich also said the that the heat on manifold on driver side will get hotter than other side - a tad more with an FWC.
Does this sound correct you guys out there?
I am going to replace sending unit and see if I can get temp to reflect correctly, then keep a close eye on manifold heat.
I will post pics later on today.
again thanks, and I am so excited to get this baby in the water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 4:26pm
Mark,
I'm glad to hear you're making some head way, getting answers and things are looking normal. I wouldn't worry about the steam out the tail end. Depending on the dew point you will get it. Since the starboard side is running hotter, it most likely got to the point where you got steam.
BTW, regarding the temp sender problem, don't shop at Autozone!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 4:43pm
Thanks Pete,
BTW love the ski tique and the year 77' :)
The steam is rising off the manifold area not the tail (I have cover off motor). I think it maybe from various oils and residues on manifold from building engine and so forth. The riser is cool. the motor is warm.
I think once I have a chance to run the boat in open water the increased flow pressure will cool it down a little.
I will shoot video of steam and post it soon.
Thanks again bud.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 8:41pm
water does take its easier path and yes at times will favor one side more than the other, how hot is hot? if you dont have access to a digital thermometer, simply put a heat thermometer on there and get some temp readings, they are exhaust manifolds and will get hot. one good way to gauge if you think they are getting excessively hot is to put some water on the hot manifold and if it instantly boils then you know its past 212 degrees.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2011 at 11:29pm
Thanks Eric,
I will use that test and get back to this post.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 1:07am
What is the highest "safe" temp you can run at? I noticed my temps creeping up close to 190 at the end of the season. I am getting ready to put in a new circulation pump though. Came yesterday in the mail. Good shape and the internals look brand new. Hope that cools her down a few degrees.
1973 Skier
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 7:05am
I dont know the max but that is getting hot, water boils at 212 degrees. I have a 145 degree thermostat, usually run at 150 to 155. Hopefully the pump resolves the problem.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 8:55am
Keegan and Dave,
You really do not want to get the engine close to boiling unless you have a FWC system. If it boils, the steam/air pockets don't tranfer the heat. On a FWC closed system like a car, the pressurization keeps the boiling from happening and the reason they can run pretty hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 2:28pm
That makes sense. I wondered why a car could run so much hotter. I hope the new circulation pump brings the temp down.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 2:40pm
Not that a circ pump failure couldnt cause you to overheat, but that sure doesnt seem to be a common cause on these engines.
Were you running hot at idle or at speed?
If at idle, you likely had an air leak- most likely a loose hose clamp. Its best to tighten them with a socket rather than a screwdriver.
If at speed, then you either have a blockage in a line, a failing impeller, or a RWP needing a rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 4:53pm
TR,
Thanks.
The boat has not made it out of driveway. Still testing before first run.
I changed temp unit and same problem - temp is starting at 200 and going over 240.
I am thinking a few things:
1. vapor lock near sending unit - my test to remove cap from FWC and see if temp comes down.
2. test sending unit by running new wire to see if somehow the original wire is compromised and the OHMs have been modified to make gauge read high.
3. check with gauge manufacture VDO / telefelx to see what unit is designed for their gauge.
How does that sound to you guys?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 4:59pm
Good troubleshooting tips Tim thanks.
I think it would run hot after a WOT run and seemed to stay hot longer than usual. That was a few months ago now so I dont remember exactly what was going on. My RWP is 3 years old and seems to be in great shape. I pulled the impeller when I winterized and it looks good but I will replace it anyway.
Could be a leak in the hose from the trans oil cooler since that is the only one I have not replaced. Blockage is certainly a possibility. I guess if its still running hot I will replace the hose and do a good poking around to look for blockage.
1973 Skier
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:05pm
As Pete stated earlier, you need to make certain that the gauge and sender are meant for each other. I had a similar problem when I redid the Mustang. The supplier had shipped the wrong pair, and I had haywire temp readings. I finally got them to their research and they provided the correct sender.
I always suggest that people get a laser temp gun. I like RayTek ones. They are cheap and are a great tool to have in the bag.
edit:   Make sure you don't use teflon or anything for a thread sealer on the sender. You lose your ground and it will not work.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:10pm
just opened cap to FWC and started motor.
for a brief second the temp did start out about 160, but climbed to over 240 within 2 minutes.
Going to check ground on gauge.
I know I need to check the temp gauge reading against actual temp of motor.
any suggestions how to do that ?
And where should i test ? (take sending unit out after heat up and test water under intake ???)
fellas ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:15pm
I think the easiest way is with a laser temp gun as Mike suggested. Harbor Freight has one on sale right now.
Good to know about the teflon tape. My sender is wrapped in teflon for sure.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:17pm
Will teflon kill your oil pressure sender too. Have not been able to get that to work and know it is teflon taped too.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:19pm
Wakeslayer thank you
I do have some pipe tread compound with teflon on unit threads ....I never knew that.
I will clean and try and get back to you guys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:36pm
Ok, cleaned the threads on both unit and intake.
Restarted with cap on and off of FWC and still
Same Problem
could my gauge not be grounded good.
Will be at all day tomorrow. got to get some work done today.
Need some suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:55pm
If youre seeing 200 degrees cold, then clearly you still have a mismatched gauge/sender.
Where did you get the replacement?
If you can hold your hand on the riser comfortably when the engine is supposedly "hot" then clearly you are not really overheating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 5:57pm
Is it safe to presume that you returned the boat to idle after running at WOT? This is probably the most stringent test for the cooling system (very hard operation followed by minimal cooling ability at low RPM) so any weaknesses will reveal themselves. If getting back up on plane brought the temp back down, then you would likely have a minor air leak somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 6:17pm
Same Problem
The engine block is the ground to the gauge. You should get zero ohms between the sender body and the block. The "hot" side to the circuit goes to the gauge itself. The ground on the gauge is only for the lighting. Sender resistance varies along with the temp it picks up and basically varies the voltage to the gauge. The temp gauge is really a volt meter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZenZeus Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 6:42pm
ok,
Then maybe the original hot wire is compromised somewhere between gauge and unit ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 8:03pm
Its gonna be 65 here all weekend but I have too many things apart to go out for a test run. This sounds about right. I bet the original hose is cracked somewhere.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 10:00pm
ok,
No. If "comprimised", you ether wouldn't get any reading on the gauge (you do) or if the wire/connections/terminals corroded causing high resistance, then the gauge would read low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-11-2011 at 11:15pm
Im not sure if they are there on the weekends,but here is the VDO tech support line 1-800-265-1818
