  New Posts New Posts RSS Feed - Sealer
Sealer
TimSpangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Topic: Sealer
    Posted: March-31-2011 at 9:11pm
What brand / type of sealer is recommended for things like platform brackets and fins?   i noticed when i temoved my platform that the brackets. are a bit loose.   I want to seal the when i tighten them up.
thanks
MMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MMT Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2011 at 10:03pm
What year is the boat? If it's a pre '94 chances are you have a wood rot. I'm fixing the same issues right now.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2011 at 10:13pm
Tim - 3M4200 is the best sealer for items you want to take apart someday. 3M5200 is even better but much harder to cut through if you want to remove it. I have found both of these at Walmart.
Good luck
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2011 at 11:02am
I know there are new stringers in my future for sure. I picked this boat up to late in the winter to start that this year. New stringers are on the schedule for the fall. I want to get one season with this boat before I tear it apart.
As for the lags in the platform brackets, they tighten up with no slipping (that one must just have vibrated loose or was never fully tighten from before). I want to take the brackets off and seal the lags and put everything pack together. I had the platform off to clean and oil it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2011 at 11:06am
Good luck
Chris
Thanks Chris, I'll check Wal-Mart. I assume it was in the auto section? Maybe I will get one of each just to have on hand. So I would use the 5200 on things like the fins, log, and strut?
