  New Posts New Posts RSS Feed - Ballast Pump Wiring '99 Air
Cincytique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cincytique Quote  Post ReplyReply Direct Link To This Post Topic: Ballast Pump Wiring '99 Air
    Posted: June-24-2011 at 8:58pm
No power going to the ballast tank pumps (Attwood 750's). The 99 Air has 1 attwood wired for filling and a 2nd attwood wired for emptying the tanks. I have been using a voltage meter and found there is zero power being delivered to either pump. The bilge pump works w/o issue; just no power at the ballast pumps.
Before I go thru the painful process of tracing the wiring from the switch (by the throttle lever)into the maze of wiring bundles under the gunnels and then through the dash, does anyone know which switch on the dash controls the power to the ballast pumps? Open to any other ideas as well! Many thanks.
1999 Air
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2011 at 11:11am
IIRC there is an inline fuse going to the full/empty switch. My switch was near the throttle lever, seem to recall the fuse being in that area behind the throttle, if not you should be able to trace the wire up under the dash.
Don't recall if you needed one of the dash buttons on or not for the ballast pumps to work, you could turn them all on and see if the pumps work and then turn off one by one as a process of elimination.
bokaeser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bokaeser Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2011 at 4:07am
I've got the same problem. Let me known if you figure it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cincytique Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2011 at 8:08pm
Thank you. There is an inline fuse, after tracing the wiring all the way from switch to dash, it was located only 3" down the main power line from the key switch behind the dash. 4A fuse blown. Unfortunately, I forgot the boat keys (stored indoor and 20 minutes away from the house) and wasn't able to test it today. Given it was blown, I am hoping this was it. Also seeing it is wired directly into the key/ignition, we know it is not running off a dash button. Thanks again! I will get back out and test it this week.
1999 Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cincytique Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2011 at 11:53pm
So I grabbed the keys and went back to test the inline fuse replacement. Success rate is 50%. The "fill" pump runs without issue. I switched it to empty and the rear "empty" pump ran for about 1 second and stopped... fuse blown.    Any thoughts?
1999 Air
liquidforce38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote liquidforce38 Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2011 at 1:45am
Mitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote liquidforce38 Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2011 at 1:53am
I would suggest follow the wire's to see of there are any broken spots. If there are not any exposed wires which would cause the pump to short out I would take the pump out and bench test it. Depending on your results you may find a faulty pump, or the pump my be working fine which would tell you there is another issue. (depending upon how hard it is to remove the pump I would test that first before I chase wires.)
Mitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote bokaeser Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2011 at 3:24am
I had the same fuse blown. I have not checked the pumps yet but I'm not sure I would have found it without you already finding the location. "3 inches from the key" really helped. Thanks. I am willing to bet you have a pump that is rusted up and drawing more load than the fuse can handle.
