  New Posts New Posts RSS Feed - Starter Relay (Solenoid)
John View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Quote  Post ReplyReply Direct Link To This Post Topic: Starter Relay (Solenoid)
    Posted: March-13-2004 at 4:58pm
Does anyone have the wiring diagram or a digital picture they can send me of how to hook up a starter relay (solenoid) on my 1979 Ski Nautique? I am having a strange problem. On a cold start the engine will fire right up, then after running for a while after the engine gets turned off, the ingintion switch will not start the boat. It acts as if it is dead. It is an intermitent problem. I have tried replacing the solenoid before but it keeps happening. can anyone help me with a suggestion of what the problem might be?
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2004 at 10:16pm
you should be able to test the solenoid fairly easily when it dies with a short wire or the screwdriver method if you don't have any fuel leaks.
i would look at the key switch, neutral safety switch and the engine ground. when in doubt smack the starter with a hammer. it's a ford.
