BW Velvet drive pump installed backwards? |
tleed
Senior Member Joined: August-24-2004 Location: United States Status: Offline Points: 267 |
Posted: August-15-2005 at 2:43pm |
I put my boat in the water Sunday and started it up with the newly-rebuilt tranny and had no go-power. The prop shaft would not spin.
I called the very helpful people at skidim (disclaimer: the tranny was locally rebuilt, not by skidim) and the fellow there told me I had possibly mounted the pump at the front 180 degrees out of whack. So I guess I get to pull the tranny again and check it out. Oh fun! When I pulled the tranny the first time, I also took the bellhousing off, too. But I'm wondering if I have to do that or if I can just pull the tranny. The boat is a '69 Barracuda with 318 Chrysler. And feel free to chime in with other salient advice. Thomas |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11155 |
Hi tleed
This can get confusing but if you have a RH rotation engine then your transmission pump needs to be set for LH rotation for everything to work. RH would be looking from the back of the engine towards the front and LH for the transmission is looking at the transmission towards the back from the front. About now your head is probably rotating because it sounds kinda back-asswards but that's how it should be. If your engine is LH rotation, then the transmission needs to be set for RH rotation. You should be able to pull just the transmission and leave the bellhousing on the engine. Good luck keno |
tleed
Pulled the transmission last night and, yes, the pump was backwards. My mechanic-buddy, who has little-to-no experience with boats was shocked and amazed to discover that the motor runs in reverse rotation from the way a car motor turns. Moreover, the pump on this transmission has two sets of holes inside the tranny so you can set the pump both ways, depending on the rotation of the engine.
To make a long story short, we reversed the pump, and now I have go-power! Look out, fishies, here I come! Thomas |
