New tique |
pswann
Senior Member Joined: August-31-2005 Location: United States Status: Offline Points: 115 |
Posted: September-25-2005 at 1:50pm |
I am here to have a good time and I will post some pics to show my good time. Do I have to replace the entire impeller or can I just replace the rubber part?
stang72
pswann...the impeller is the rubber part!Well rubber and brass that is...
Get a new impeller and the O ring for the housing...Talk to Vince at Skidim so you get the right one...get a spare while your at it. |
stang72
Forgot to mention...if you know what manufacturer made your water pump..that will help...should have numbers on it.
Looks like that thing is shreaded...thats why it's not in one piece.A new impeller will have the brass fitting inside the rubber fin section...it is one unit,Hope that clears things up for you. |
79nautique
Guest |
That thing is shreaded and has seen some serious heat. Try and flush the system most likely there are some small chucks of rubber from the impeller floating in the coolant jacket. Try and flush it out as best you can to avoid an over heating problem caused be blockage. remove the drain plugs on the back of the exhaust mainfolds, flush the lower hose to the circulation pump and the plugs in the block, one for each side. Use an air hose or water to flush it out and keep and eye on the temp gauge when you get it back on the water. Make sure you put the raw water pump back together correctly because you can get it backwards. If memory serves me right the set screw on the side of the pump needs to point towards the out side or away from the engine for the correct rotation of the pump.
pswann
I pulled all the hoses and checked for loose parts. Got it all cleaned up and put back together. I am running it without the manifolds so I can monitor the water output. Kinda loud but that is what ear protection is for. Temp is holding fine at 160. I cannot get it to run below 1000 RPM without dying. I ordered a chrome dress up kit that will make it look much better. I am picking up a rebuilt holly tomorrow and I will throw that on. If I cannot get that tuned in I will throw a spare AFB I keep for rainy days. At least I know how to set an AFB up.
79nautique
Guest |
double check for vaccum leaks around the carb and intake and maybe open up the idle mixture screws a little more. Check and re-adjust the timing and idle mixture screws until you get the idle down. With the high idle it can make the timing advanced some at idle. use a vaccum gauge to help adjust the carb if it's a holley. And don't assume that the dash tach is correct. if you have a newer style timing light use it for the rpm to double check the gauge.
pswann
79 you are good! I just talked to the previous owner and he said the same thing! A vacuum leak. I had the valve covers on with only 2 screws on each just to hold them in place. I would try it today but I already started an oil change. I am going to have to become familiar with these hollys. I am getting closer and closer to launching this rocket!
79nautique
Guest |
You need the idle down to set the timing correctly otherwise you can have it over timed on the top end and have a ping problem. I would suggest leaving the motor box off the first couple of times you go out until you get the timing dial in. The box will muffle a ping and with it off it's easy to hear it. Good luck and keep us posted. Also check the timing at 3k it should be a little over 30 degrees don't get it over 35 degrees. Checking it at this rpm will let you know if the mecanical advance is working correctly.
