  New Posts New Posts RSS Feed - Wobble in the shaft
Wobble in the shaft
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Topic: Wobble in the shaft
    Posted: September-28-2005 at 2:12pm
I notice that when I am in forward, but at idle speed there is a slight wobble in the coupling, where the packing nut is on the drive shaft. I have a '69 Ski Nautique. I don't notice any vibration when cruising however. I am assuming this wobble is due to the alignment being slightly off. With this being the first season of having the boat, I'm not sure if this wobble falls into the "normal" range. Should there be no noticable wobble at idle speed?
Walk on Water
www.coldwater.me
69 Ski Nautique
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2005 at 2:22pm
When it's spinning, it should look round.
Tim D
