  New Posts New Posts RSS Feed - Airguide test proceedure
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Topic: Airguide test proceedure
    Posted: May-03-2012 at 10:37am
Forum, I am getting to the assembly stage of my rebuild and would like to test my speedos prior to installing the fuel cell. Is there a simple test to perform such as 5PSI = 20MPH (made up numbers) ? What is a failure symptom of the aluminum tubes vs actual gauge?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2012 at 10:45am
Should have Googled first.. my bad. 30psi= 50mph and I just found out that the equalizers tubes aren't needed and are recommended for removal. Do you agree?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2012 at 11:00am
It depends on the age of the gauge. I'd leave them in on older gauges. (roughly pre mid 80's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2012 at 11:03am
These are 1978 Pete. I am lead to understand they slow the action of the speedometer. I ride in areas with rather short runs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2012 at 11:50am
I'd leave them in. They where designed to slow down the gauge needle movement so they aren't bouncing all over the place but also, the dampening is easier on the gauge internals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2012 at 11:54am
Gotcha, theyll stay. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2012 at 12:55pm
Just make sure they don't leak I found a small crack in one of mine (leaked like a sieve)
After repair I put hose on each end dropped it in a bucket and pressure tested.
