  New Posts New Posts RSS Feed - commander marine engine ???
jfergvt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfergvt Quote  Post ReplyReply Direct Link To This Post Topic: commander marine engine ???
    Posted: October-08-2012 at 11:47pm
Hi,
I hope it's not fighting words but I own a 1987 malibu skier, not a Nautique. (Maybe someday I can afford one) It has a commander marine 300 engine (ford 351). i have been searching in vain trying to find a manual for the engine. Could anyone point me in the right direction?
Thanks,
Jeff
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: October-09-2012 at 2:03pm
Check out our reference section:
http://www.correctcraftfan.com/reference/manuals.asp
If you want one pre-printed:
http://www.skidim.com/searchprods.asp?searchstring=manual&pagenumber=1&val=0
I have manual 4201 and it seems to have a lot of good info. Most of it is general Ford, and not necessarily PCM specific
Most of the manuals are PCM Ford, but there should be enough similarities to help you. I know a lot of guys on this site have the Commander Ford as well, so you should be able to get good advice on specific questions.
I think most guys on here would give you more grief about tubing than than they would about brand of boat
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2012 at 7:00pm
What all do you need for the commander? I stashed a parts book away somewhere I will have to find but none of the part numbers cross refference so it's basically useless other than looking at cool commander pictures. PCM does make an impeller that will service the Commander style pump. Plug wires and distributor stuff is the same if it is spinning a pertronix. Carburetion and fuel related parts should be the same as long as it's a holley carb/Carter pump.
Other dudes that own Commanders will chime in and know lots more than me.
