How many hours ? |
jacmurr
Newbie Joined: June-15-2012 Location: Sebastian, Fl Status: Offline Points: 28 |
Posted: December-04-2012 at 9:48pm |
The hour meter currently reads 1468.2. Is that alot for a well maintained 351W? She runs awesome! My boat is a '76 CC 210 Cuddy. How many hours can I expect to put on it before having rebuild/replace the engine? And yes, it is a saltwater boat.
Thanks |
Jack's Off
chicagozalewski
Groupie Joined: October-29-2012 Location: Chicago Status: Offline Points: 40 |
what is the compression engine?
+/- 2500 hour |
baitkiller
My guess is that its not the original engine. My guess is also that if you turn the key on you can sit back and watch the hour meter run without the engine actually being started.
So disregard the hour meter and do a practical evaluation of the propulsion system from the pulleys to the prop. SW boat the risers and exhaust manifolds are your biggest concern. A compression or leak down test is crucial. Very important you know how old the manifolds and riser are. John |
phatsat67
PCM reccomended 2200 I believe on the carbed Fords. Many have gone far longer just depends on the usage type and care.
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
I left my key on once and added 160 hours to the meter
This is the life
phatsat67
oh no! false hours are the worst.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
I have been told that on average the Top Ends will last 1500 and the bottom end around 3000 hours. However, the compression check is the thing to check.
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13515 |
is there an echo in here? here? |
Donald80SN
Hollywood,
No, that is just how we speak in the South. Donald |
