  New Posts New Posts RSS Feed - 91 SN steering picture
N2Deep View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote N2Deep Quote  Post ReplyReply Direct Link To This Post Topic: 91 SN steering picture
    Posted: February-12-2013 at 5:18pm
Anybody that has a 91 SN I am trying to fix my steering wheel issue. If you could take a picture of your steering wheel and dash that would be helpful. I am not sure I have an original wheel and the part between the wheel and dash dont line up. Trying to correct the issue so a picture would help and hopefully someone has some spare parts.
I need a steering wheel that is keyed and the part that goes between the wheel and dash.
I got a steering wheel of Kevin but its splined from a 93 if anybody needs one. I will post it up in parts for sale shortly.
1991 SN pulled by a 2010 Tundra
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2013 at 6:28pm
Craig - did you ever get the help you needed?
Kevin
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2013 at 6:33pm
93 was the first year for a splined hub. That is when the switched happened to rack and pinion style helms. I believe some 92's sneaked out with the new steering style. Prior everything was a keyed hub and a rotoray style helm.
No pictures of early boats sorry.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2013 at 3:51pm
Craig:
There are some very nice replacement steering wheels out there..... it depends on your boat and your taste what to replace it with. If you do buy another steering wheel, most of the time they will be supplied with the hub and center cap as well. If you just need a hub, make sure you get a keyed, tapered hub whose bolt pattern matches your current wheel .... Like the one shown here:
Steering Wheel Hub - Keyed tapered Teleflex
Or you can get an entire new wheel, hub and center cap like this:
Schmitt Steering Wheel New
Hope that gives you a place to start...... Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote N2Deep Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2013 at 6:00pm
I had great plans for the weekend - Pull the boat out, change the oil, start on the new gauges, install the new steering wheel, new plugs and get her ready to float. Well I didn't even touch it cause the garage door broke and I didn't want to deal with it.
I did have a relaxing weekend but got little done. Maybe next weekend. :)
Boat_Drinks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boat_Drinks Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2013 at 5:04pm
Hello,
A little late to the party, but I have a 1991 SN that I could take some pictures of for you if you are still in need. Everything appears to be original except for the Tach which I just replaced. Let me know if your interested.
Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote N2Deep Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2013 at 4:30pm
Thanks but I got a new steering wheel - I just need to find the time to get the boat ready. I have a handful of things that need to be done.
