Anyone seen one of these Steering cables? |
Post Reply | Page 12> |
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
Posted: March-05-2013 at 10:53pm |
So the steering cable on my boat is completely non-functional (i knew this when i bought it).
I've been having a hard time figuring out how I'm going to replace this thing since it's stamp fit on both ends to the respective hardware. Here it is before I removed it from the dash. Off the steering column. The steering wheel end. Number on the cable. This is at the rudder end. Anyone have one of these for sale? |
1999 Ski Nautique 196
storm34
Looks like a typical steering cable from that era. I posted my struggles with ours in the 96 a few years back.
Zach will chime in here shortly and get you hooked up! |
phatsat67
Standard cable for that year. 1993 marked the year they switched to rack and pinion style with that box gear on the end. It comes as an assembly. They are way cheaper than the rotary style cables.
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
Changed mine out a few years ago on my 93 Sport. Pretty easy really.
Was the same set up. Cable and rack are integrated into one piece, bolts right up. I would tie a rope to the stern end of that existing cable and pull it out from behind bulkhead-kick panel. Can't tell from the picture, but you probably have a removable kick panel. Then attach the new cable to the rope and pull it back through to the stern of the boat. |
KRoundy
Zach or other places can get you the right parts. There are differences between some of the early years and you have to get the exact right length.
Frankenotter
Continuing the steering problem, here is the link to the replacement.
Cable You'll notice that the original racks are smaller than the new ones. Guess which one I have They start at $300 and the helm is another $125. That's why I was interested in the used cable for the time being. If it was in good condition and the size I needed, it could have been a temp fix until I get the funds back to replace everything. My cable right now is completely seized. I'm of the mentality of doing things the right way and I know most of you have seen my progress with this boat, but I'm running low on boat money. Most people send a few years overhauling their projects, but all of mine have come within a month of purchase and I haven't even bought new manifolds yet. Ill get through it but that's why I was looking at a used cable. |
lewy2001
Chris the direct Teleflex replacement cable is only $195 OEM is $299.
This is not like the older rotary steering cables where you had to buy OEM to get the correct throw length. The rotary racks changed in 98 to the wider 1.75" compared to the earlier 1.25". If your helm is still ok you can just buy a cable to suit your earlier helm. I would think on the Tique you could get away with a shorter cable than 20' The SSC12479 number you have looks to be a old Teleflex number. Try this Cable link Go2M |
Frankenotter
Can I? So far all I've been offered is the 1.75" OEM for $300. Ok ill do some more calling. It sucks doing research from a phone.
Thanks mark. |
lewy2001
Chis just edited previous post.
Frankenotter
Thanks again mark for looking that up. I call tomorrow and see how familiar they are with my boat.
Later this week when I get home I will pull the old cable out and measure it. Everyone I've talked to about this cable says its the same one as the 196's. I think I literally talked to too many people when researching these and everyone had a different idea about what I had. It started to get a little confusing. |
TX Foilhead
The new cheaper cable cost is offset by the fact that you have to buy the new helm to use it, it's pretty much a wash for the first one. You will save money on the second if you still have the boat then. I tried the new one and didn't like it. On my boat it made me very nervous to turn around at speed in the river arm where we ride. Nothing gets your attention like being halfway through a turn and wondering if the boat will make it or if its going to hit the shore.
Frankenotter
Don by "the new one" are you referring to the one in the link from mark?
What about This one? Does this come in the old helm style? What made you distrust the new style cable? Did it feel different? What are you using now and where did you get it? |
lewy2001
Chris I think that is a good plan measure your existing cable. That link to go2Marine also has the video on the way to measure steering cables. The last 2 digits signify the length in feet of the cable. I doubt though your original cable is 79 feet long. The SSC124XX back mount rack cables will fit onto your original helm. This makes it a more cost effective repair than replacing the helm in addition to the fitment of the new style SSC134XX rack cables. These new style cables (SSC134XX) use the TFXtreme technology in them. Not sure if the older style SSC124xx have that option available. I doubt you will find these old style rack cables at your average Nautique dealership. If so they may be just be old stock. Skidim list the new style TFXtreme cables in lengths from 15-24 feet. Skidim SSC134 Rack Cables Buying the old style SSC124XX cable new for $140 is much better than purchasing a second hand cable. If money was no obstacle changing to new style helm and new SSC134XX TFXtreme cable could be better long term option. Hope this clears it up for you. |
Frankenotter
Mark once again thank you. Great information.
I will put an order out as soon as I determine the correct length and I will document the process here for anyone in the same predicament. One question however, what is the advantage of the newer (wider) helm gear? Would you notice any difference in handling or is it one of those "nice to have" situations? Chris |
TX Foilhead
The new cable won't fit on the old helm, the tilt is the same mechanism. The trow on the new cable is shorter so you loose a little bit of angle on the rudder at each end. On the Excel, which is the worse handling boat they ever made, that was a big deal at speed, not really noticeable at idle or going straight. My turning radius probably got 20ft larger which makes a big difference in a river with concrete walls on each side. I could make the turn, but the wheel was all the way to lock, very weird feeling knowing there is no room for error and hoping you hit your mark when you started to turn. I could drive it, but I worried about letting others do it who didn't realize it didn't drive the same since you had to get very close to the walls and docks on both sides. If I stayed in open water it might not have ever been an issue.
Frankenotter
So, I just called Go2Marine and talked to their steering cable guy. I gave him the original number off my cable that's in the boat and of course, he was thrown off by the last digits (ssc12479). The last two digits obviously indicates the length of the cable from the rack to the stop fitting.
We both agreed the boat was not 79ft long and had a discussion about the rack width. He knew right away that I needed the 1.25" rack. I asked him if the size of the rack effects the throw at all and he claimed "no" quite confidently. He said the "ssc124" part of the cable number is the same weather it's OEM or not. This makes sense because there is no way to increase throw of a cable without increasing the length (not width) of the rack. If you look at the link I posted to nautiqueparts.com, it looks like the length of both size racks are about the same. For me to switch to the 1.75" helm with my adjustable steering wheel would cost over $300 not including the cable. Sorry I'm not saying your wrong but I just want to cover all my angles so I don't wind up with a reduced maneuverability. All the cables I've researched have the same hardware and the only variable is the length of the teleflex. I feel like I'm getting close to a revelation. Is there a known dimension or documented detail about throw or are we just talking about how they feel. I'm not being a smart a$$ or sarcastic, I'm just trying to see the picture in the puzzle. Chris |
Call Teleflex's tech line Chris,they should know their product teleflex
KRoundy
I don't want to add more confusion but.... what I find interesting here is that your helm in the photos above appears turned 180-degrees from the way mine is oriented. In both the 1993 SN boats I've owned the rack goes on the top of the helm, where yours attaches from underneath. I wonder why it is different? Besides that flip, everything there looks exactly the same as what is above my knees.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21185 |
The direction of the rack will depend on which way the rudder tiller arm faces (port vs. stbd), which is opposite the side CC put the single exhaust on. I know my '90 had the cable run down the port side, but I believe CC switched sides sometime in the mid 90's... so that may explain the difference youre seeing. |
KRoundy
OH! That makes complete sense. Thanks, Benj. I was not thinking about the impact flipping over the rack would have on the other end of the line.
Frankenotter
So I just got off the phone with the man at teleflex. Super cool guy that had finally laid this question to rest.
First........my odd number on the original cable. It was the old coding that signified 1/2 feet. My cable is 19.5 feet in the boat so it was coded as 79. They don't make 1/2 foot sizes anymore. Second and most importantly..........the throw. He has never known of a difference in travel as long as they've made these cables. He said at one point it was probable that the gear ratio of the rack changed but that would only equate to more or less turns of the wheel to achieve the same rudder deflection. Third.........the designation of the rack dimension. SSC124 = 1.25" rack. I know we have already established this but for the sake of anyone in this situation in the future, he said ORDER A SSC12420. Supposedly they are All the same. I will be ordering with confidence later this week. |
TX Foilhead
Just so you're not confused, that was a special cable mate for CC, the only place to get it is from a dealer. The new one has a wider and thinner rack, bolt holes line up but the gears won't touch. I haven't put the old and the new helm together to check the difference, but I can if you want to see and I get home in time.
Frankenotter
Don if you can find a difference please let me know. At this point I've talked to boat dealers, marine distributors, and teleflex themselves. Nobody can find a difference as long as the cable says ssc12420 on it.
This is one of those little details that could have slipped through the cracks so if you have both of them, maybe you can bust this myth. |
lewy2001
Don I think you are confusing the cable helm and with the rack. The steering cable for cable helm 1982-1990 was a OEM part only that had a different throw to the standard cables. This cable was only available through dealers. Here is the SSC12420 Cable from Go2Marine The rack cable has the same throw. Does not mater if it is purchased at the dealer, Teleflex or elsewhere. Don you may have had the Morse rack helm that was only used from 91-92 according to Skidim. Must have had some left over for your 93 Excel. This is what is causing the confusion. Chris will have the Teleflex helm on his 96 Tique that will take the Teleflex cable. |
Frankenotter
For what it's worth that is about the same thing Art Cozier told me. I sent him pictures of my setup and he made a comment that this was a model that I didn't have to worry about the throw.
lewy2001
Don it would be good if you could clarify if your old helm was a Morse unit.
I think we may have covered some ground here that Skidim had already traveled. All good information for future reference on this amazing resource site. CC sure did some changing about with there early rack and pinion setups. I also remember Jody mentioning something in a old thread about the rack and pinion steering systems. He and Art would be able to confirm what happened back at the factory. Cool when we can have it confirmed by the people who actually made these boats. |
TX Foilhead
Old rack side. Old rack top New rack side New rack top New helm top New helm side Old helm top OK, I'm not finding much difference in the parts so I'm questioning my setup a little. It will be easier to measure things when I get them all out of the boat, there is a size and fit difference between the 2 so pieces aren't interchangeable. For now I need to tarp this back up and get back to work on the bilge, I'll have more time on Thursday for measurements, and I think I can still get my old cable out of the dumpster to check it as well. |
Frankenotter
The pictures of old vs new look like the difference between 1.75" vs 1.25" or ssc124 vs ssc134 cables. They are two different cables altogether.
The difference, if there is one, is between the two racks. Do you have a picture of the 2 racks side by side? |
TX Foilhead
The racks are different sizes, I couldn't get them side by side because 1 is in the boat the other was laying over the gunwhale. Give me a couple of days and I'll have time to get the cable pulled, I still have to get the seat out and finish thanking the stereo apart.
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
gonna hafta change the helm too. unless there is something I'm missing.
should just be a cable and helm change unless you want tilt too then you get new tilt too. If I'm not mistaken it's just that simple. |
This is the life
