Mufflers |
72Martinique
Newbie Joined: February-12-2006 Location: United States Status: Offline Points: 4 |
Posted: February-12-2006 at 9:29am |
I have a 1972 Martinique, and it is missing the original mufflers. I wanted to add a pair, but I have a space issue. The mufflers would have to be less than 4" in diameter, probably more like 3.75". I also was hoping to get some that would make it as quiet as possible. Has anyone had this issue, and does anyone know where to get mufflers that would fit my needs?
-Matt |
79nautique
skidim.com
72Martinique
After consulting White Lake Marina, the boat didnt come with mufflers new, and there arent any that would fit in that small space, apparently. My new question is, has anyone used cuved exause tips that would put the exaust directly in the water, or know where you would get them? I remember seeing them advertised in a wakeboarding mag a while back but i dont seem to have the issue still.
JEFF KOSTIS
A high-rise type (PCM) stle manifold will help lower the tone if you have log style manifolds. Definately a 50% or so reduction that Ive noticed. I say forget the stereo, and let the engine spit flames out of the rear with the water!!!
Im not sure, but I thought someone had mufflers that went inline with the exhaust hose that was the same size... Might have to do some foam removal??? Not familiar with that hull.. Jeff.... |
Bob's2001
Senior Member Joined: March-28-2005 Location: Lake Jackson TX Status: Offline Points: 241 |
I don't know if this would work for you, or even it works, but it was posted over on PlanetNautique
freshairexhaust |
Bob Ed
83 2001 |
