Battery Issue - HELP! |
gpax
Newbie Joined: July-09-2013 Location: United States Status: Offline Points: 18 |
Posted: July-09-2013 at 4:46pm |
Long time reader. New poster.
I'm having issues solving a problem with my what I believe is my battery connection. For a long time my boat (97 Sport GT40) had a real problem turning all the way over. Sometimes it wouldn't do anything when I turned the key. I would have to go out and remove the battery and jiggle the wires and it would start right up. I changed out the connectors, brushed off any rest on the metal and it worked great for a few outings after that. My most recent trip out it got back to not starting at all. Again I jiggles the wires and it started. But when I went to place the battery back in the compartment the engine cut off. I finally got it started back up and it seems to cut off every time we hit a wake (I assume when the wires moved at all). Any idea what this is? The battery itself (only a year old), need new battery cables that run to the engine? |
Hollywood
Time for new cables, just do it. Plenty of threads on this too do a google search.
Randy_in_Ohio
+1 on the cables. Even if they look fine, replace them. I had problem replaced the cables and not a problem since. Like HW said, just do it. |
gpax
Thanks. Do you know where I can get those cables from? I checked nautiqueparts.com and couldn't find them anywhere.
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
There's a guy on ebay that does custom marine battery cables: Greg's Marine Wire Supplies
Good prices and highly rated. |
- Jeff
1999 Ski Nautique |
Randy_in_Ohio
there was a place someone recommended here I can't think of the name, I have the receipt at home... I can get it for you in a couple hours but the link above looks good too.
I would pull them and measure them before I place the order. and let them put the ends on. unless you can solder them yourself. I would make sure they are soldered and not just clamped on. do it right and you'll never have another problem. |
catamount
Newbie Joined: May-29-2013 Location: Vermont Status: Offline Points: 45 |
Probably: http://genuinedealz.com/ The guy who runs it is incredible. Free shipping, and if you don't have a crimping device or heat gun he'll make the connections for you for an paltry $1/connection. His prices on marine grade electrical supplies beat all others. |
1987 MC ProStar 190
SNobsessed
A good auto parts store will custom make them for you. Just take the old ones in for them to copy.
Yes, but I suggest marine cable. Each wire strand is tin plated to avoid all the corrosion problems. |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
[/QUOTE] Probably: http://genuinedealz.com/ The guy who runs it is incredible. Free shipping, and if you don't have a crimping device or heat gun he'll make the connections for you for an paltry $1/connection. His prices on marine grade electrical supplies beat all others.[/QUOTE] +1 I highly recommend these people. They did a great job on my cables. Donald |
Randy_in_Ohio
Yep,that was it Donald. Great prices, great service and fast!
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Huge +1 for genuinedealz.com. Top notch outfit.
