timing the bow tie. |
baitkiller
Posted: July-12-2013 at 9:02pm |
Not a Ford fellas.
I have a 5.7 Vortech with the Mercruiser HP stuff, High rise intake, Webber marine (AFB) 4bbl. When I put it together I set the timing at 29* full advance. Now after about 50 hours running Im beginning to hear a a little ping. I always run premium 93 oct. pump gas from the local Haji Mart and also tried a full tank MTBE from the fuel dock. Still pings in the low power band, 3-4K then it clears up. The thing runs absolutely flawless otherwise. Thoughts / suggestions? Too high? This is the high compression version. Tested at 213 psi cold. |
baitkiller
Google is my friend.
Thanks. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
Too aggressive on the advance curve?
What ignitions in it? |
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
What Alan Said. Also are you using non Ethanol Fuel ? Some stations up here offer premium 90 to 93 octane with No Ethanol content. I work a an auto Restoration shop and every spring we get customers complaining about detonation. We ask about fuel and always get the I use Premium answer. We then ask from where... I do not know if this is offered where you are but you may want to look into it. |
