  New Posts New Posts RSS Feed - Water laeking into Battery Box
tlwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlwolf Quote  Post ReplyReply Direct Link To This Post Topic: Water laeking into Battery Box
    Posted: August-01-2013 at 7:09pm
I have a 2011 200 OB SN. The other day the bow went under a wave and took on quite a bit of water. There was at least 6” in the bilge which I pumped out & the bilge is now empty. The battery compartment had 3” of water which did not drain out to the bilge area. I got that out, but water keeps bubbling up through the drain hole in the bottom of the compartment. I’ve emptied it 3 times and the water keeps coming. I would have thought that all water taken on board would drain to the bilge? Apparently not as whatever water is trapped is still going into the battery compartment. Anyone know the cause and what to do about it? Thanks.
Bay Rat
juno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juno Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 9:27am
I have same problem in a 1982 Mustang and am about to glass it off
No real reason to have an operational drain hole there
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 9:56am
That is why I turned that box into a beer cooler and put the battery under the dash.
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 11:39am
Funny to see this thread now... I was just going thru my entire boat and noticed a 1/2 of water in my battery box. I pulled the little drain plug out (that I just put in at beginning of season just because I thought it would be a good idea). I have a closed bow too! Must have been the day skiing in the rain.
Anyway, I guess it is best to just leave the plug out... anyone else do this?
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 12:09pm
tlwolf - Is the boat stored in the water or is it on a trailer after skiing that it is doing this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2014 at 12:39pm
That is odd... do you have water in bilge higher than bottom of battery box?
Take and air compressor hose and blow the drain line clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlwolf Quote  Post ReplyReply Direct Link To This Post Posted: August-09-2014 at 1:21pm
I posted the original question. I did eventually figure it out. A piece of foam padding had come loose and lodged where the drain passage was cut in a spar between the forward section and the aft bilge motor area.
This caused the water to build up in the forward section and eventually into the batter box. The foam padding was supposed to be under the muffler box to manage vibration between it and the hull.
Bay Rat
