  New Posts New Posts RSS Feed - points upgraid ???????
josh84/2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh84/2001 Quote  Post ReplyReply Direct Link To This Post Topic: points upgraid ???????
    Posted: March-17-2006 at 11:11am
what product should I get and who makes the best product and who should I buy from.
surroundsound64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote surroundsound64 Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2006 at 12:05pm
Call a dealer.
1981 Ski Nautique
2000 SAN
Looking for a 2000-2006 SAN
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2006 at 12:08pm
If you just want to upgrade from points electronic ignition I'd buy the kit that SkiDIM sells. I believe it's $100-$120.
If you really want to go all out buy a custom calibrated marine HEI distributor from Performance Distributors
Atmspltr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Atmspltr Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2006 at 12:46pm
I've used Pertronix to eliminate points in some old cars and have been very happy. Just need to know you need to bypass the resistor wire to give full 12vdc to the Pertronix. Points systems use resistor wire to reduce voltage so that the points don't burn up. Pertronix will run for a few hours and then die out. Pretty easy modification.
john33617 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john33617 Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2006 at 1:25pm
this one is for a clip down cap , installed mine with the ballast works fine.             http://www.amarket.com/imptppp8.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh84/2001 Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2006 at 2:36pm
thanks john that was a lot cheeper than the dealer.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2006 at 11:25pm
read instructions, verify system resistance to determind weather or not to bypass balast resister .02
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2006 at 6:00am
I put a Petronix kit on my 66 Barracuda. Best 100 bucks I very spent. Really easy to install. When you hace the old points mounting plate off, make sure you lubricate the manual advance wiehgts and aprings before you put the new plate on
