  New Posts New Posts RSS Feed - Another Carb question
racingnc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote racingnc Quote  Post ReplyReply Direct Link To This Post Topic: Another Carb question
    Posted: April-14-2014 at 7:21pm
I recently rebuilt my 4150 carb works great until I shut the boat off. I noticed fuel flowing out of one of the main jets. My question is what might be the culprit.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2014 at 12:05am
A stuck float would be my guess.
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2014 at 9:32am
+1 stuck primary float (you mean one of the front "barrels" looking down at it ???)
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2014 at 10:03am
Stuck float is possible but it's more likely to be a bad needle/seat following a carb rebuild. Pretty common in new Holleys these days (both new carbs and rebuild kits). Hope you kept the old one!
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2014 at 10:36am
Don't rule out the float being set too high. That's happened more than once here after a rebuild. Especially if you have a 1:1 tranny and no angled carb adapter.
Eddie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2014 at 11:01am
Agree with everything. Check all WHEN you pull the bowl off.
- waterdog -
78 Ski Tique
cadunkle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadunkle Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2014 at 6:35pm
Clean or replace needle and seat, reset float level... May just need to set a hair lower. Could also be heat soak, it will expand or boil the fuel and cause some dripping and ensuing flooded hard start condition. I used a thin (1/2" IIRC) phenolic spacer on mine to help isolate the carb from heat soak.
Also, extreme carb angle will cause flooding out the front bowls unless float level is set lower than normal. Angled spacer will help and many direct drives had these from the factory, sometimes discarded over the years.
