MerCruiser Starter in my 77 Chrysler 318? |
Rockymtnsalom
Newbie Joined: May-29-2014 Location: Colorado Status: Offline Points: 13 |
Posted: June-23-2014 at 11:32pm |
Hi so I'm preaty sure my starter when out on my 1970 ski nautique. at first it would just make a loud click and then sorta turn over some times. I tightend the conection from the silinoid to the starter and then it made a bunch of nasty grinding noises when i tried to start it and now it just makes a loud click again when I go to start it. my first question is does this seem like a reasonable asumption on my part that its the starter?
my second question is that when I looked at the starter it aprears to be a MerCruiser which seems odd. the part number is 50-69865 which came up as MerCruiser when I googled it. what I was expecting was 2875928 which would be the seemingly correct part for a LM318. what should I do, Should I order the starter that is the right one for the boat or buy a Mercruiser replacement one? I apprecait all the help and responces! I would be toalty lost without this site |
Rockymtnsalom
If it worked in the past I IMHO would get it rebuilt. If its a reverse rotation those parts don't exactly grow on trees. There are other reasons for that clicking too,35 year old cables,bad connections,deep cycle battery instead of a correct starting battery and the resulting bad solenoid.
Rockymtnsalom
I have a optima Blue top batery on it currently. is it posible that this fried the silinoid? the silinoid was my first thought but its only a few years old and then when the loud grinding made me lean more toawds a bad starter I apprecaite the help! |
Should not be the problem then,it could be the cables if they are old or the connections need cleaning at both ends or the starter just may be tired
Rockymtnsalom
The starter is fairly new so I'll give the cables a shot. Thanks for the help!
oldcuda
Senior Member Joined: June-22-2010 Status: Offline Points: 474 |
I take mine apart clean and reassemble every couple years. you would be amazed how much crud,rust,scale accumulation there is after just a couple years. Make sure bendix is smooth and no broken springs they are simple and last forever.Most I ever put in is a set of brushes and have gotten some pretty crusty ones back in service.
Rockymtnsalom
My Benix has a couple spots were its shiny from the starter butting it. The teeth are still there though. Is that ok? Or is that possible why I'm burning though starters? (2 in the last 5 years) |
oldcuda
They should last a lot longer I would inspect the mounting surfaces to be sure there isn't something causing the starter to be tilted towards flywheel.Maybe somewhere along the the line the wrong starter was installed and you are following it with the same part number.Sound like a lot to do but I would coat the bendix with Dykem and crank it a couple times to see where the contact points are against the ring gear.
