  New Posts New Posts RSS Feed - Stern light socket '75 SN
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Topic: Stern light socket '75 SN
    Posted: July-05-2014 at 11:42am
Dad's stern light socket corroded on the inside beyond repair. Can't find a close enough replacement thus far. He wants to butcher it and I can't let it happen, I'm an original type of person. Any help? I'm sure the sockets common on most 70's CC.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2014 at 12:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2014 at 12:38pm
Pictures of what your looking for always help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2014 at 1:06pm
He bought the Attwood. The Attwood looks like it but is actually a shorter surface area, exposing a screw hole on deck from the original. And the socket base is bigger in diameter so I'd have to make existing approx 1" hole in deck larger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2014 at 1:08pm
Tried uploading pics but some error comes up saying CCF isn't compatible. IDK, ill try again later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2014 at 9:51pm
   Sweet, thanks to Keith's hard work tonight I can post this pic of the stern light I need.
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2014 at 4:10am
I was able to drive out the black plastic part inside that has the two prongs on it. I cleaned everything up, and re-soldered wires to the underside of the prongs. Once it was all ready, I just pushed it back down inside. Works fine. However, I don't know how bad your is.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2014 at 7:56am
We thought about that, actually thought about replacing the bottom part of the socket with new but that created another snaff-foo, i forget what it was now. His prongs are pretty well toast. Then I figured, surely theres one on here somewhere for less of a headache.
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2014 at 11:37am
Yeah, that is a nice looking piece of hardware. I'd hold out; one has to pop up here from a parts boat sooner or later.
You'd think it would be easy to gut a new one and use the vintage chrome base but I doubt the plastic would match up correctly. Maybe call perko and see if they can refurb yours?
Cocacola works good on corrosion. I just had to clean my 99s.
Nice boats and Good luck.
illiniball2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2014 at 9:43pm
I just bought a 71 Barracuda off eBay. I will see if it has one when I get it. Could be a week or so though.
Thanks,
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2014 at 10:12pm
Thanks, keep me posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2014 at 7:51pm
I'm going to pick it up on Sunday. So hopefully I can let you know soon thereafter.
Thanks,
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-01-2014 at 8:22pm
The style used through '72 or so is not the same as the one pictured.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2014 at 11:40pm
The one on the boat I bought isn't the same. It twists instead if slides.
So don't know if that is something you would want to change.
Thanks,
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2014 at 7:52am
I appreciate you checking but I'm gonna wait for the correct one. Actually at this point thinking if making one. Thanks.
