  New Posts New Posts RSS Feed - Prop taper fit ok?
Prop taper fit ok?
mbshaw88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Topic: Prop taper fit ok?
    Posted: March-16-2015 at 3:58pm
ACME 540 on a '82SN.
Picture taken after 20 turns of valve compound.
I'm seeing the rotation marks along the entire taper length, but it seems to be a little darker near the end. This is my first time fitting a prop so I want to make sure it's done correctly. Do I need a few more rotations with the compound or is it ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 7:33pm
Keep going! Notice the real high spot at the forward end of the taper. The blue should be even fore to aft. I also recommend some finer lapping compound.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 9:10pm
Ok I'll give it another go tomorrow. Appreciate the response!
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2015 at 1:26pm
What does the inside of the prop bore look like? You want at least 80 % of the ID to clean up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2015 at 10:53am
After using the compound again, the prop bore has a smooth lapped finish through the entire length.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2015 at 12:18pm
Your good to go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2015 at 7:44pm
Considering how fat off the taper fit was, I suggest checking with the Prussian blue again.
