General questions: |
73SN
Senior Member Joined: October-05-2005 Location: United States Status: Offline Points: 147 |
Posted: June-14-2015 at 5:24am |
I was hoping to get my engine in this weekend but I had a few hold-ups. 1.) I need a new ring gear on my flywheel. '73 - 351W Tonight I tried Ford Mustang Mach I with 5.8L 4bbl on Amazon and it says it matches the ZA-501 I saw where Watauga changed his (page 4) but I'm just not sure if the Amazon one is the right size. Anyone else done this? 2.) Also I was thinking, when I go to start this thing there will be no water in the block. Should I pop out the temperature sender and pour in a gallon or so beforehand? Thanks, Paul |
Paul,
I'd count the teeth to be sure. The water won't hurt but for a short run I don't feel it's needed. |
I believe that the 501 (164 tooth) is the wrong ring gear... You want the 503 (157 tooth).
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=34350&title=bad-flywheel |
illiniball2000
Senior Member Joined: June-27-2014 Location: Elgin,IL Status: Offline Points: 386 |
I just had this same issue. We went to Car Quest and they ordered one and had it next day for $20
Beer is my friend
87 Dominique Had 67 Starflite |
Tim, Thanks for searching for the ring gear. |
73SN
awww man, I was counting on the map gas to get the job done.
Thanks, I had searched flywheel but not ring gear. 157 is the count. I'll cancel the order... I'll check around this afternoon maybe someone will have one. Is there a downside to the ring flip? If cleaning and map gas wont work I guess I'm waiting anyway. |
Everyone has a bbq grill,if your careful get everything ready and carefully heat the gear in it.
73SN
I got the new ring gear in today. The flywheel went in the freezer and I heated the ring with MAP gas. It literally dropped on:
The old and new side-by-side: |
