  New Posts New Posts RSS Feed - water pump not initiating
wakespirit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Topic: water pump not initiating
    Posted: July-05-2015 at 6:50am
Dear all, I have notice thta no water flow correctly from water pump on my correct craft 2001,
I could see some small amout of waater atvthe water pump input but does not go further.
In order to try to initiate it, I remove the tuve from the pump and pump some water directly inside the pump in case it is too dry, but no luck.
Is there a better way to initiate the water pump befor I try to desasembling all?
Regards
Serge
Smithfamily View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2015 at 9:34am
Are you talking about the engine driven water pump? That circulates water through the engine to cool it? Picture?
Js
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2015 at 9:36am
Sounds like a bad impeller. It is supposed to be self priming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2015 at 1:30pm
Yes it is the impeller area may be needed to remove it ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2015 at 7:41pm
Check all hose connections to make sure they are tight. If nothing bad there, then i would inspect the impeller. That is only a 30 minute job, so nothing to lose there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2015 at 4:24pm
I finnaly buy a new impeller kit for my water pump.
But then even after ths Ivhave a strange issue.
When I star the motor i can see the water rising up in the tube but then after a while the motor temerature rise up. It seem that at idle speed the ampunt of waterwhich troval is not enough.
If i put some gaz in neutral more water are coming because motor run faster rpm and then temperature drop down to 160F.. Then back to idle without gaz and temperature eaise up again
What could it be ? Bad idle speed?
Thanks for help
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2015 at 7:38pm
Serge,
Sounds like you are sucking air on the suction side of the pump. Check all your hose connections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2015 at 8:30pm
Ok will cross check that . Does ansmaml hole n a hose could cause this ?
Is there other things I could check excpet this or it is jist a metter of air ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakespirit Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2015 at 3:24pm
I finnaly discover a small hole on one water hose at location you tight it. I bougth a new hose and all is working ok now. Water debit from pump is perfect at idel and high speed and motor temp remains around 150F.
Thanks for all your help
Regards
