Rocker pedestal torque. |
Morto
Groupie Joined: November-09-2005 Location: Brunei Darussalam Status: Offline Points: 47 |
Posted: May-30-2006 at 1:53am |
Hi all, anyone know what torque is recommended for the rocker pedestals in a PCM352W? And what about the exhaust manifold bolts?
Thanks. |
Morto
I mean "PCM351W"!
79nautique
what year? and are you sure it's a pedistal and not a stud type? Normally they are a rail type system from the factory and to have one or the other type rockers means the head's have been changed.
For the exhaust use some anti seize lube on the bolts and use your calibrated arm to torque them. Get them good and tight but not super tight. |
Morto
Yeah, sorry - it is the old rail type system. Two rockers held down by one stud, I think this particular engine is around '92 (the boat is an '82) Any idea?
79nautique
use your calibrated arm to torque. Get them tight but don't strong arm it, start in the center working towards the ends alternated front to back, snuck them evenly then torque them evenly as descriped. If they where pedstal studs then you need to use a torque wrench, but not on the rail systems or studs with the later be adjusted while running.
Morto
Thanks. Here I go.........
SS-201
Senior Member Joined: October-20-2003 Location: United States Status: Offline Points: 105 |
Be sure you preload the rockers.
SS 201
