Ski pylon |
Page 12> |
Author | ||
Darkwing420 ![]() Newbie ![]() Joined: July-27-2015 Location: Haslet tx Status: Offline Points: 25 |
![]() ![]() ![]() ![]() ![]() Posted: September-07-2015 at 1:33pm |
Does anyone know if there is usually any kind of small extension for pylon or is it always just right above engine cover??? I just bought an 81 ski nautique and the back tow ring is loose so I can't pull with it but would like for people to be able to sit in back seat while I'm pulling
The rear lifting ring is NOT designed for towing anything!! It's NOT a "tow ring"! Get rid of the passengers in the aft when pulling. BTW, never pull tubes even with the pylon.
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5334 |
If you are wanting to pull wakeboarders, combo skiers, trick skiers, or kneeboarders then you'll need to purchase a Super Deluxe Boom Mount and a extended pylon. If you want to use a Skylon, Fly High or some other extended pylon then you will need to remove the existing Ring & Finger set up from the pylon and slide the extended over the factory pylon. PLEEEEEEEEASE, DO NOT CUT or HACK UP what you currently have to make it work. The Ring & Finger tow points are in HIGH demand as they are not made anymore and is considered criminal to destroy it to modify the exisiting to accomodate the extended one.
As Pete stated the rear 'Tow Eye' aka Lifting Ring that you are using was designed for verticle loads only (ie lifting boat in the boat house) and not for towing. That's why its loose. You purchased an Inboard Tournament Competition Ski Boat so yes all pylons are in front of the engine unless it's a V-Drive boat. |
Duck, Considering the lifting ring is loose, I HIGHLY suggest you investigate why it's loose BEFORE you use it for it's intended purpose of lifting the boat!! Yes, as Tim mentions, you purchased a competition ski boat. |
Ok thanks I never towed with it it was loose when I got the boat and I won't be rigging anything I'm appreciative of the classic original design of boat and don't want to rig it but it would be ok to get fly high and slide it on pylon without damaging anything and it will fit over pylon??
Yes on the extended pylon ("fly high") but make sure you rig the forward cable correctly. The cable does not go to the forward lifting ring but is rather connected to a strap around the stem. |
Ok awesome thank you sir it hooks to the eye on the front of the boat where the trailer hooks on to it correct
Yes, Duck that is correct.... Attaching the support cable to the FRONT lifting ring has been known to cause spider cracking in the gelcoat round the lifting ring. Some have managed to get away with it but I wouldn't risk it. IMHO. |
Ok thanks again I appreciate it took it out this weekend and everything was good except that they had an automotive coil they put on and it would get really hot then the boat would start to misfire when taking off from idle and die then it wouldn't start back up until it cooled off.. I put about 30 hrs of labor in it after purchasing it and thought I had everything right kind of disappointing but atleast it's a small issue and easy to fix I'm just new to boat game except for my dad owning one while growing up so I'm trying to learn as much as possible
Duck, There really isn't any coil that's "automotive" or "marine". The key is it's need to be used with a ballast resistor or not. The resister lowers the voltage. |
i have the old one he took off and they do both say use with external resistor which the engine does have but I thought maybe since some parts are marine specific and the new one is cheap from autozone that maybe that's why it was getting so hot then it would bog down and die after I let the coil cool or took it off and cooled it in water then put it back on it would start right up and run great for another 30 min or so then die and coil would be hot again..is it normal for that to get really hot and if it's not a defective coil what would cause it to get hot
Duck,
Your first mistake is going to Autozone. Sorry but I feel they are the absolute worst with any parts. Check the voltage going to the coil. A internally resisted coil will take the full nominal 12 volts. An externally resisted coil wants around 9 volts after the resistor. Then find out what coil you purchased. Also, an oil filled coil doesn't like to be laid on it's side and in the typical mounting position of many on marine engines. Epoxy filled coils will handle any mounting position. |
Yes sir I agree about autozone I purchased the boat from a friend who purchased from original owner.. My friend had intentions on fixing up and flipping the boat so he did little things here and there like the coil before giving up and letting it sit for a yr before I bought it so that's why it is from autozone I only use napa and I'm a heavy equipment mechanic just not real savvy on old engines but I will look into the voltage and I am pretty sure it's oil filled.. But it shouldn't be getting hot right?? Also with it getting hot there isn't something else that could cause it to overheat other than the wrong type of coil or it being cheap
skyfuzz ![]() Senior Member ![]() ![]() Joined: August-17-2004 Location: South Florida Status: Offline Points: 239 |
I didn't have a proper ski pylon for my '70 Barracuda, so I used the aft lift ring to attach the ski rope to when pulling skiers, kneeboarders and tubes. I did this for 7 seasons when I owned the boat. Although it was only maybe 4-5 times each summer, I assumed the aft lift ring would handle the load no problem. I also used both the aft lift ring and the forward lift ring to tie the boat to the dock. So, I suppose you could say, that I just learned something valuable here today! Yikes, had no idea what I was risking! Thanks Pete! The Wildcat I own now is pylonless and having one installed when the stringer/floor job gets underway. |
http://www.correctcraftfan.com/diaries/details.asp?ID=7613&sort=&pagenum=1
JPASS ![]() Grand Poobah ![]() ![]() Joined: June-17-2013 Location: Orlando Status: Offline Points: 2283 |
I'm currently selling a 10" pole and wakeboard rack. The ID of the pole is 2.5", $125 for the whole set-up + shipping.
Let me know if you're interested. Original Posting |
'92 Correctcraft Ski Nautique
Ok when I get home from work I'll measure my pylon not for sure what size it is and I'll let u know
Someone else just PM'd me for it. If the deal falls through, I'll let you know.
gun-driver ![]() Grand Poobah ![]() Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4128 |
Pete this is so not true!!!! My '85 has an oil filled coil that was mounted on its side when I bought it and still is to this day. As long as the ohm rating is correct, it's getting the proper voltage and your ballast resistor is working properly it will work just fine on its side. Here is all the part #'s for a prestolite clip down distributor the 1.5 written on the coil box in pen is the ohm rating. I can dig up the condenser # also if you need it. ![]() |
74Wind ![]() Grand Poobah ![]() ![]() Joined: August-02-2011 Location: Georgia Status: Offline Points: 2101 |
Before I found him a pylon, my brother used the rear ring on a 72 Southwind for many years, with up to 8 skiers, on a very frequent basis, as they live on the lake. My friend has also used the ring on his 72 Coronado forever. Neither boat has ever shown even the slightest bit of damage from this. Or maybe older boats were just built better.....
While I won't challenge this prevailing wisdom in theory, there have been numerous past threads on this but never any real proof. Pics or it didn't happen.. ![]() |
1974 Southwind 18
1975 Century Mark II |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
I've heard of gel/glass damage with extended pylons to the front ring and towing from the rear ring. I've also heard of damaged cam shafts (low zinc) and blown up boats (non-operational blower). We used to ski off the rear ring and have the Skylon hooked through the front ring. Can't say I was as strict on using the blower either then. Don't be the kind that waits for something to happen to improve your ways.
Jeff, 8 teenage skiers on two skis isn't even equal to 1 full size adult on 1 ski. Sorry but your logic won't make me change my mind. Have you ever even looked at how the aft ring is fastened to the transom? |
Yes sir I agree with you when I got the boat and noticed it was loose I removed tank to see what it would take to fix it and it's pretty apparent that it's not a very strong design for anything but upward force I was shocked and scratching my head at why they would make it that way but once it was explained that it's not for towing I understood why completely
Maybe why some of the newer ones have a spool mounted on the back? I find when pulling a tube from the spool you get a better "crack the whip" action than from the pylon. I think in this off season I'll develop a rear "tube" tower or flyhigh type of device. Now that Pete will be living on the water full time he just might want to up his tube game. I hesitate to get the TimmyT marketing team,might go with cousin Don and get coveted CG rating instead.
Weird assumption, never said anything about teenagers......ages 8-65 last time as I recall, fun stuff. Like I said, i don't argue with prevailing wisdom, and of course it's better for the boat off a pylon Pete. Just seen a whole lotta skiing off the ring on a whole bunch of old inboards, many wood, in my lifetime, and never once ever heard, or seen, a peep about any resulting damage, just hearsay. Like I asked. ..got actual proof or pics? Skiing has been around since long before the advent of the pylon and not all old boats were so equipped.....think Joe Cash ever refused a pull from the ring? ![]() |
1974 Southwind 18
DrCC ![]() Grand Poobah ![]() ![]() Joined: April-12-2004 Location: at home Status: Offline Points: 2886 |
So, what do you say to a family in distress with an infant on board and it's getting dark? - "Sorry, can't help you"?
If you can't tow with it, you probably shouldn't be lifting with it. We used a Southwind 20 as a service boat for years and years. Towed 50+ft houseboats for 30+ miles. Always towed with the lift ring and never the pylon. Never seen any gel stress. |
Well, there ya go, case in point,...... thanks Doc!
Reminds me of another thread which strongly debunked the use of the four beefy correct craft factory-installed cleats for tying up...... as they are purportedly ill-equipped for such purpose; and recommending the use of the apparently vertical-pull only lifting eyes for dock lines instead. ...... ![]() ![]() ![]() |
1974 Southwind 18
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21210 |
Any particular reason why you wouldn't tow from the pylon Al? Seems like it's better suited for the job. I've seen more than a few lifting rings surrounded by gel cracks. I can't state definitively where they came from, none have appeared on my boats under my ownership. 2 screws (at most) and a snug fit in the deck is all that holds the lifting rings in place laterally. I suppose the vertical rod below adds some strength in that direction as well, but that's not really its purpose (a vertical load is). We all know that correct craft construction is pretty beefy, and the thick deck can take the abuse for the most part. I'm sure many a skier have been pulled from them without issue. To Pete's point, that still doesn't make them suitable for the job. Use your best judgement, I suppose. |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7966 |
The ski pylons were optional on most of the boats up until the 70's. Plenty of people have pulled from the rear lifting ring, including my family that had a '67 Cuda for 10 years. We never had any stress cracks. No doubt some boats get them, but they also show up in other areas of the deck, like the corners of the back seat.
Bow eyes were optional also, and many people moored their boats from the front lifting ring. |
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6132 |
I'm having a little trouble buying this. I've never seen a slalom skier who knows what he is doing, do anything but pop right up behind any inboard. Say that's about 175-200 pounds. Eight (smaller) skiers is going on 1000 pounds or better. Any group ski I have seen with 4, 5, 6, or more, it takes a little bit of work on the part of the boat and a few yards to get them all up. The use the lifting ring for pulling argument will live on. Many say they've seen it done for ever, especially on the older boats without pylons, will argue their point and folks who have seen some spider cracks will argue their point. But like many of the extreme positions held here, lets be reasonable. To say a boat shouldn't be tied to a dock with the lifting rings because they are for lifting only, is just plain silly. |
For the longest time Correct Craft used the same method for horizontal stabilization of the lifting ring as the pylon. 2 pieces of 3/4" plywood. I would rather tow another boat off the lifting ring than the pylon. Both can being overloaded if you tow too fast, but there's a lot more leverage applied to the pylon.
Page 12> |
